09-13-2015 08:25 AM
09-13-2015 09:11 AM
Your camera stops the lens down when TAKING the photo. It keeps it wide open for focusing. There should be a button you can press to see it stop down. (check your manual for the location.)
09-13-2015 09:18 AM
09-13-2015 09:18 AM
It depends on the lens. It should be open while focusing. You can not stop it down until you set something on the camera. Canon lenses do not work the same way as some Nikon lenses do. They must be locked at minimum aperture to work.
As the previous answer says you have a DOF preview button somewhere on the camera which allows you to see the lens stopped down to f20.
f20, is there a reason to use f20? Just curious.
09-13-2015 09:24 AM
09-13-2015 09:46 AM
Certainly OK. It is just not a commonly used f stop.
09-13-2015 09:51 AM
