08-31-2015 08:43 AM - edited 08-31-2015 08:44 AM
08-31-2015 10:22 AM
There is a seperate manual that came with your 6D which covers the WiFi and GPS functionality. It's not in the main manual (some countries restrict use of WiFi or GPS - so Canon includes this documentation in a separate manual for countries where the camera includes WiFi & GPS functionality.)
There is an option to either enable or disable the log function. With logging off, the images will be tagged, but the camera will not record a log of your movement.
In the GPS menu, there's the option to either disable the GPS, or enable the internal or external GPS (i.e. the Canon GP-E2 GPS), but there's also a setup menu. In the setup menu you'll see an option caled "GPS Logger". The camera's GPS will only record the log file if that option is enabled. ALSO, if instead of using USB to transfer images you are using the camera's SD card, the GPS log wont be on that card (even if logging is enabled) unless you return to that logging menu and use the option to "Transfer log to data card".
Also of interest... there is an option to change the GPS update interval. I noticed the Canon doesn't mention the impact of this on battery life for the 6D, but I have a 5D III with the external Canon GP-E2 module and they DO mention how the update interval impacts battery life. The default update interval is 15 seconds. I set mine to 30 seconds since I'm typically walking when using the camera and I tend to find a spot with an interesting subject and remain there for some time while I shoot... I don't need the GPS to update my position very often.
As you've already discovered, if you "enable" the GPS, then it remains enabled at all times when the battery is in the camera -- even if the camera itself is "off". There has been quite a bit of discussion on this and Canon seems to indicate that they did this because GPS can take a bit of time to acquire a position fix and they didn't want users to power off their camera for a moment (e.g. when changing lenses for example), power the camera back on, and then have no position data for a few minutes as they attempt to resume shooting. I think the general concensus of the community is that the community wishes Canon would have configured a delay timer (e.g. don't power off right away -- that way simply switching off the camera to swap lenses wouldn't shut off the GPS, but do power off after some period of time -- perhaps 30 minutes.) While that sounds like a reasonable solution, there has been no firmware update to change the way the camera & GPS manage power.
If you leave the GPS running and do not remove the battery, then you'll likely discover that the battery is depleted the following day.
09-06-2015 02:38 PM
Okay. I've paid more careful attention to what I do. I have nailed down the exact reason why my GPS files would sometimes not download. It was more than enabling the GPS logs. The internal GPS needs to enabled at the time when you download images, in order for the logs to be also transferred.
My normal routine is to drive a couple of hours to location, shoot for a couple of hours, drive home, and then download the files. I would turn off the GPS for the drive home. I tried to download files, and was not prompted for GPS logs. Disconnect camera, enable the internal GPS, reconnect camera, and BINGO.....I'm prompted for the GPS files when I download images. Hope this helps somebody.
08-31-2015 10:22 AM
08-31-2015 11:27 AM
08-31-2015 12:36 PM - edited 08-31-2015 12:38 PM
09-01-2015 06:25 PM
After some experimenting with different folders, GPS enabled and disabled, I cannot reproduce the issue. It's working as expected. I suspect that I didn't notice the elephant n the room. Thanks for the interest, folks.
09-06-2015 02:38 PM
