12-04-2019 03:17 AM
I'm using my 5DS in an underwater housing, and no access to "Multicontroller" How to I chance items on the screen? i.e. scroll from AF operation to metering mode to drive mode, etc... I can scroll thru the AF point selection, but not the main screen. Help...
12-05-2019 01:14 AM
Hi there,
Most of the options available on the Q menu and adjsuted with the multicontroller can also be adjusted using the buttons across the top of the camera and then using the main control dial and rear control dial to make the adjustments necessary. You can find the explanation of these buttons on pages 26 and 27 of the instruction manual linked below and each button will reference a page explaining that function and button.
http://gdlp01.c-wss.com/gds/9/0300018669/03/eos5ds-5dsr-im4-en.pdf
12-05-2019 01:14 AM
Hi there,
12-05-2019 03:02 AM
Thank you, that is a big help. Not sure why I didn't see that, as I felt like I went thru the manual a dozen times. Greatly appreciated!
jc
