04-29-2017 03:49 PM - edited 04-29-2017 04:16 PM
I Canon 5D Mark IV. In evaluative mode, I am trying to half press the shutter to lock the AF but not the AE. By default it locks the AE and AF. I have been through all the settings (custom) and I do not see that option.
And yes I have reviewed the manual and googled this before posting.
I know this had to be a setting. Help!
05-10-2017 10:35 AM
@TCampbell wrote:
@manatee4mation wrote:If you have any Canon DSLR you can see that you are not correct. Press the shutter half way and hold in in P, AV, or TV and the meter is locked into that exposure. Period. Move the camera. Point it at the sun. The original exposure is locked.
In M, if you have auto ISO, the ISO will change with the shutter half-pressed. If you do not auto-ISO, the exposure comp will change.
Hi Manatee4mation,
You may want to reset your camera to factory defaults. The above statement is not correct. A Canon EOS camera will (by default) continously update the metering as you continue to hold the shutter button and move the camera.
If you are not seeing it update the metering continuously as you half-press the button and move the camera to areas with different lighting, then something has been changed on your camera.
You can lock the metering by pressing the AE Lock button (by default it's the asterisk on the back of the camera but it can be re-assigned) and if you do this, THEN the metering will lock in and re-composing the shot will not update the exposure. The 5D IV has two modes for this.... the default version of AE Lock only locks until you take a shot (or until you let the camera metering system switch off (e.g. if you are looking through the viewfinder and the digital metering & shooting info goes dark... that clears an AE Lock.) The other version is an AE Lock + Hold. That version (the "Hold") maintains the exposure lock until you cancel it... or refresh it with new metering... or until you switch off the camera.
Hey Tim,
You have a Mark II and III. I have the Mark III and IV. As much as I wish you were correct, you demostrably not. Just testt the camera to see I am right. Do the same test I am doing below. Record your results in the reply.
I am doing the below with both the III and IV right now.
1. My camera is at the default settings.
2. I am in evaluative metering mode.
3. Set first on One Shot; next on AI Focus.
4 Press the shutter half way, confirn focus lock
5. Look at the meter (shutter speed, Aperature and ISO) Reads - 1.4, 60, 200 ISO
4. Move the camera, keeping the focus locked with the half-shutter press, point at a lighter or darker area - I get the same meter reading - it does not change.
Also, from the Canon Mark IV Manual, Page 100
With evaluative metering (p.253), the exposure setting will be set at the same time as focus is achieved.
While you hold down the shutter button halfway, the focus will be locked. You can then recompose the shot if desired.
I spoke to Canon and they confirmed that there is no way around this. Prove me and Canon wrong. Do the test. Record your results in the reply to this.
Ira
05-10-2017 11:33 AM
Hey Tim,
Ira
Hi Ira,
I currently have a 5D III and a 5D IV. I just recently sold my 5D II.
Ok, now I see what you're saying... in "One Shot" it only updates metering if you release & re-activate the metering button.
In "AI Servo" it will update continuously as you move the camera around.
I was doing this in "AI Servo" mode because the last event I was shooting was a cycling event. "AI Servo" isn't really an option for you becasue you mentioned you want to lock focus and not have it update when you re-compose. The back-button focus will give you the control (it will ONLY update focus when the "AF-ON" button is pressed if you choose this behavior) which gives you the ability to isolate the metering function from the focus function.
Best Regards,
Tim
05-10-2017 01:06 PM
@TCampbell wrote:
@manatee4mation wrote:Hey Tim,
Ira
Hi Ira,
Best Regards,
Tim
Tim,
Exactly. This all started because I wanted to be creative in camera. And I wanted to do it quickly and I am much quicker with the half-press shutter than I am with the back-button controls.
I guess what I struggle with is why this is not a custom setting. There is nothing mechanically or logically preventing it. As I noted, Nikon and Sony make it an option.
Thank you for your time and thoughts.
Ira
05-10-2017 01:12 PM
@RobertTheFat wrote:
@manatee4mation wrote:The meter timer has nothing to do with the AE lock on half-shutter. Meter timing is a battery saving setting. It defaults to be a very quick 6 seconds so the camera can get the maximum battery life.
Here is how meter timing works.
1. Half press the shutter and release. The meter is now active for the length of the meter timing setting.
2. Half press the shutter and hold . Exposure meter is locked.
Anyone with any Canon DSLR can test this out.
Can you point us to any supporting Canon documentation? I've yet to run across anything by Canon that mentions the metering timer and battery life in the same paragraph.
Incidentally, the instruction manual says that the metering timeout on a 5D4 is four seconds, not six. On a 5D3 I surmise that it's 10 seconds, because that's what mine is set to and I can't think of a reason why I would have changed it.
Hi Bob,
You are right about the default metering timer. 5D4 is four seconds. I was wrong. I had read in a review a while back that that metering timer is a battery life issue. Nothing that i know of in the manual.
On my underlying issue, see page 100 of the 5D4 manual.
This looks like a dead horse. Unless I convnce Canon to act like Nikon and offer the custom control I want, I will have to use the back button controls.
