09-09-2016 03:51 PM
I need help, I bought a Soligor 3X tele-converter for use with my Tamron 150~600 mm lens, the body is a 60D. The problem is when I try to take a shot I get an error message "Err 01 Communications between the camera and lens is faulty. Clean the lens contacts." So I try a Canon 50mm f/1.4 with the Soligor 3X tele-converter & works fine. Any suggestions at to why this tele-converter won't work with my Tamron lens? I thought there is just a ribbon inside the TC to make a connection.
PS.. I also tried the Tamron 150~600mm & TC with my girlfriends Rebel and I get the same message. I have a 1.4X and a 2.0X TCs and the Tamron 150~600 mm lens works just fine. Also I did clean the contacts on each end of the 3X TC. thanks, Blair
09-09-2016 04:05 PM
I would suspect that the error message is fairly generic, and would apply to any type of communication error, INCLUDING bad data. The bad data that I am thinking of would be f/stop, which in this case would be as high as f/16 being reported ot the camera.. The camera rejects that numbers as bad data, out of range, etc.
09-19-2016 05:36 PM
well my copy of LR6 arrived today time for me to start learning how to use this application and the world of editing. With cooler weather and shoter days coming on I'll have plenty of time.
09-19-2016 06:49 PM - edited 09-19-2016 06:50 PM
@BlairW wrote:well my copy of LR6 arrived today time for me to start learning how to use this application and the world of editing. With cooler weather and shoter days coming on I'll have plenty of time.
Just remember. Don't do a Creative Cloud trial on the same machine with LR6. In fact, if you do a trial, use a completely different Adobe login, on a completely different machine. Okay?
Have fun. My favorite feature is the ability to apply "Preset" settings during Import. This is where I use it to automatically apply lens correction. If you are familiar with DPP, you should catch on to LR6 basics pretty fast.
09-20-2016 10:16 AM
"...time for me to start learning how to use this application and the world of editing"
Great photos are not made in the camera, they are created in post editing. 99% of all the professional/commercial photos you see are edited in PS and/or LR.
09-20-2016 10:32 AM
Blair,
I would not try to pull from your DPP experience, if any, to use in Lightroom. Terms may be similar but the two software's are different. LR is way more intuitive than DPP. Not only do you need to learn how the presets work but you need to learn how plug-ins work. You can even d/l thousands of plug-ins for LR. They speed up your editing time tremendously.
While Canon's DPP works with just some of even Canon's own cameras, LR and its DNG Converter work with almost any camera made. However, Adobe will come out with LR7 shortly. At that point LR6 will stop being supported. They may even drop a licenced version altogether. You will still have use of the DNG Converter, though.
09-21-2016 07:42 AM
09-21-2016 10:18 AM
"...should I have waited on LR7?"
I am not a 'waiter' so I say get what you can use now. Who knows what Adobe or Canon will actually do? Besides there is a good chance LR7 will be rental only. I don't want to do that.
09-21-2016 01:05 PM
09-21-2016 10:19 AM
Blair,
If you come back with LR questions, start a new thread on the forum.
