would it be good to buy a 18-135mm F3.5-5.6) IS and a 70-300mm F4-5.6 IS both for my Canon 70D?
mauriciocayo
would it be good to buy a 18-135mm F3.5-5.6) IS + a 70-300mm F4-5.6 IS both for my Canon 70D?
Or a 18-135mm F3.5-5.6) IS + a 55-250mm F4-5.6 IS STM?
Or with a 70-200? but then budget increases too much.
what do you recommend me? i want to have fun soooon taking pictures toi animals in Sri Lanka. Later i would pick a macro to take photo to insects when i do bike trails and also the Telescopic that i should choose.
18 REPLIES 18
The lenses you mentioned are fine, actually very good, for the vast majority of amature photograhpers.
The lens I suggested is a step up lens.  And the "L" lens I recommended is a full on professional lens.  The best that Canon makes.
You will be more than happy with your original selection.  Smiley Happy   Go make some beautiful pictures!
Last question!
Which Makro lenses would you me recommend? I don't know much about it.
THanks
The Canon EF 100mm f/2.8 Macro USM Lens, with out doubt a best-buy!
thanks! and some other not sooo professional (let's say not sooo expensive) ?
" (let's say not sooo expensive)"
Unfortunately, as a recommendation from me this is going to be the least expensive choice.  There are no others I can give my blessing to. For one thing I generally don't recommend any off-brand lenses and that is where you will have to go.
Only time I will recommend an off-brand lens is if Canon does not make one or the Canon is so ridiculous high priced most folks can't afford it.
You might check out the Canon EF 50mm f/2.5 Compact Macro Standard AutoFocus Lens. I pesonally don't like it.
But it is a reasonable alternative and a little cheaper but remember not even in the same class as the EF 100mm f2.8.
Canon makes two 100mm macro lenses, the L and the “non-L” as recommended above.  Just making sure you weren’t looking at the price of the L version ($1000+) vs the non-L (< $600).  You could probably get a refurbished L directly from Canon (with warranty) for $450 or so.
I don’t have anything against third party lenses, but I agree with eBiggs on this one; Canon makes some of the best macro lenses out there, and they have a wide assortment of options at different price ranges.    Both of the 100mm macros, and the MP-E 65 are some of the best consumer options out there.  If it’s not in the budget I’d suggest saving until it is.
@Macro
What I think about 60mm is that is not heavy and easy to handel. Also it works with close fotos and open fotos, right?
I dont exactly need to take pictures just from insects, i would like to make artistic photos about things and create some stories.
Can imagine to choose a 60 instead of a 100mm?
The folks I know that have the EF-S 60mm f/2.8 Macro USM seem to be very happy with it.
 Its angle of view is equivalent to a 96mm lens on a FF body.
For a macro lens, look at the Tokina AT-X 100mm f/2.8.  Does spectacular work as a macro, and doubles as a very good portrait lens also.
"Just an old boy, and his camera"
