my 15-55 mm lens
jackierh
my 15-55 mm lens is hard to turn to adjust it also the auto focus isn't working  any suggestions.  Should I try to get it fixed or would it be best to just get another lense.  I saw some used ones that seem pretty reasonable
7 REPLIES 7
ScottyP
Could this be an 18-55 lens?
What camera body do you have?
Scott
yes, sorry.  18-55  it's a Rebel 5T.
ScottyP
It would make no economic sense to repair a kit lens like the 18-55.  Are you sure the lens is bad and not the camera?  I'd try another lens to be sure.
Scott
I already tried another lense.  It works fine.
ebiggs1
Try this:
  1. Take the lens off of your camera.
  2. Put the lens in MF mode.
  3. Twist the FOCUS ring (the tip of the lens) all the way to one side (extend it). You may hear a click noise or two, this is good, but don't FORCE the lens.
  4. Twist the FOCUS ring all the way to the opposite side (retract it). Again, you may hear a couple of clicking noises. What we hope is happening is the focusing motor being put back into its proper place.
  5. Put the lens back on the camera.
  6. Put the lens in AF mode.
  7. Turn the camera on.
  8. Put the camera in AUTO or P mode.
  9. Take a test photo.
  10. Works?
well, this worked.  the ring that changes the mm isn't changing easily, I have found that if I turn the focus ring, it will then let me adjust it.  Otherwise it stops.   but the auto focus is working again.  Thanks for your help.
Do not turn the focus ring when the AF/MF switch is set to AF.
