02-16-2025 03:46 PM
Hello All,
My EF 24-70mm f/2.8L II suddenly started having this Err 01 with my Canon 5D MkII and my 40D as well. Other lenses work well on these two bodies. It works at 2.8; but any higher, I get the Error. I have cleaned the contacts.
I see that others were having this problem as well. My lens is about 11-12 years old now. Thoughts on how to get this fixed? Can I take it to a local repair shop if any? Or should this go to Canon?
Thanks!
03-06-2026 11:19 AM
Hello All, thanks for your help! I sent this to Canon in Virginia and it came back repaired! So far working well!!
02-17-2025 10:02 AM
@Curamantel wrote:
Hello All,
Thanks!
That lens is known for ribbon cable failures that present the problem you are seeing. I don't believe Can repairs that lens any more.
02-17-2025 10:05 AM
Try this tel:+1-800-652-2666 and ask one of the techs
03-06-2026 11:19 AM
