09-11-2024 04:34 AM
I own a pretty old Canon 1000D camera from the mid 2000's and I own 2 lenses for it, the camera works fine but I'm looking for something that has a higher resolution and can record at a better quality. What would be a good beginner quality upgrade and could I use my older lenses?
09-11-2024 07:35 AM - edited 09-11-2024 07:38 AM
The recommendations we might make will depend largely on your budget. In order to use EF or EF-S lenses on a mirrorless body, you will need a Canon brand EF to EOS R adapter. Compatibility performance and function can depend on the brand and type of the lens, as well as its age.
Camera body's you may want to consider are the R50, R10 or R7. The sensor type, APS-C is similar to the one that's in your 1000d but all have two times or more the resolution.
If you want to consider a full frame camera, The R8 or R6 might be a good place to start. Note however, that If your older lenses are EF-S you will not want to use them with a full frame body. Lenses intended for cameras with smaller sensors will reduce the resolution of cameras that have a full frame sensor.
It would be helpful if you told us the brand and models of the lenses you currently own as well as an actual budget. This way we can provide more specific recommendations.
~R5 C (1.0.9.1), ~R50v ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
09-12-2024 10:49 AM
"What would be a good beginner quality upgrade and could I use my older lenses?"
There will need to be a bit more info. But, if the upgrade is to stay in a DSLR your choice for a new model is small. If you want to buy a used camera any one designed for EF and EF-S will work just fine. If on the other hand you want to go with one of the newest R series, I would not do it, if it means using your old lenses even though they could be made to fit.
