08-08-2026
02:33 PM
02:37 PM
Vivitar 8mm 1:3.5 Lens On a Canon EOS R With a Lens Adapter
Hello: I apologize if I've already posted about this. I have a Canon EOS R camera. I use a Canon adapter so that I can continue using the lenses I had on my Canon EOS Rebel. One of those lenses is a Vivitar 8mm fisheye lens. It works perfectly on the Rebel, but will not function at all on the EOS R. When I tried using the lens on the mirrorless camera, nothing worked -- the shutter button would not work; I could not get an aperture reading, nor could I get a reading on any setting on the camera. I am a technology dinosaur, so my eyes glazed over when I tried to research the issue since I encountered a lot of technojargon. I am reaching out to the Canon community for some guidance. Thank you in advance for your help.
08-10-2026 12:41 PM
@eapples ,
Let's take this further.
Try enabling crop mode on the camera's shooting menu. This might help to minimize or eliminate the vignetting you are seeing using the EF-S lens on a full frame camera. Also worth noting, using this lens on your camera will reduce its 30 megapixel image capture capability to approx 11 megapixels. Just be aware of this.
