Visible Vignetting with RF100-500 + R5
roush6ny
Hi all
Noticing vignetting when viewing in equalize mode in almost all my photos. I’ve been using the same settings for 15 years with my aviation photography and I never saw this with my old 100-400 paired with the 70D
any input would be appreciated it.
some sample photos attached (vignetting shows prior to editing)
Thank you
12 REPLIES 12
kvbarkley
What is your workflow? Are you using the Canon corrections?
jrhoffman75
Website the-digital-picture.com has a vignette tool.
Screen Shot 2025-11-30 at 06.12.43 AM.pngScreen Shot 2025-11-30 at 06.12.43 AM.png
Anonymous
Not applicable
Modern lenses often rely on software to correct faults(like vignetting). You've got to use the right software and/or profile for the lens.
johnrmoyer
"I never saw this with my old 100-400 paired with the 70D"
A crop sensor only uses the best part of the lens which is in the center. Have you tried the old 100-400 on the EOS R5?
For processing images I usually use Canon DPP on macOS or Rawtherapee on Debian Linux. I use the "digital lens correction" in DPP or the similar "capture sharpening" in Rawtherapee. Recently, I often save a 16 bit TIFF from DPP and use gimp to add a second unsharp mask with a different radius and small amount. Gimp 3 is linked with a new JPEG compression algorithm that achieves both smaller file size and higher quality than the old algorithm used by DPP and much older Linux software.
https://www.rsok.com/~jrm/2025Nov25_Salt_Plains_NWR/2025nov25_web_IMG_5079c.html
Spider web at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on November 25, 2025 ; EF100-400mm f/4.5-5.6L IS II USM +2x IIISpider web at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on November 25, 2025 ; EF100-400mm f/4.5-5.6L IS II USM +2x III
The above spiderweb was not cropped, but usually I crop.
https://www.rsok.com/~jrm/2025Nov25_Salt_Plains_NWR/2025nov25_eagle_IMG_5100c.html
Bald Eagle (Haliaeetus leucocephalus) at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on November 25, 2025Bald Eagle (Haliaeetus leucocephalus) at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on November 25, 2025
Camera Model Name Canon EOS R5
Lens Model EF100-400mm f/4.5-5.6L IS II USM +2x III
Focal Length 800 mm
Exposure Time 1/400
ISO 500
F Number 13.0
Camera Temperature 34 C
Measured EV 13.75
Measured EV 2 30
Focus Distance Upper 164.68 m
Focus Distance Lower 81.91 m
Was this lens purchased new or used?  What was the source?
ebiggs1
"I’ve been using the same settings for 15 years ... and I never saw this ..."
Something changed. Plain and simple. We know your gear has changed but what else. Are you using the same photo editor for instance?  The same lens profile or correct lens correction profile?
It is difficult to understand when you say, "I’ve been using the same settings for 15 years...", then such a drastic equipment upgrade has occurred so an adjustment to your 15 year old settings may be in order.
EOS 1DX and many lenses.
Waddizzle
 “ Noticing vignetting when viewing in equalize mode in almost all my photos. I’ve been using the same settings for 15 years with my aviation photography and I never saw this with my old 100-400 paired with the 70D “
What is “equalize mode”?
It sounds like a third party app that I am not familiar with.
Just guessing.
https://en.wikipedia.org/wiki/Histogram_equalization
I love eagle shorts.
