Visible Vignetting with RF100-500 + R5
roush6ny
Hi all
Noticing vignetting when viewing in equalize mode in almost all my photos. I’ve been using the same settings for 15 years with my aviation photography and I never saw this with my old 100-400 paired with the 70D
any input would be appreciated it.
some sample photos attached (vignetting shows prior to editing)
Thank you
12 REPLIES 12
@ebiggs1 wrote:
I love eagle shorts.
Thanks. It was handheld from my car window. I included the eagles in this ebird checklist: https://ebird.org/checklist/S286148072
It is also at: https://macaulaylibrary.org/asset/645908256
I have very little skill at video, but the 2 Eagles are at: https://www.rsok.com/~jrm/2025Nov25_Salt_Plains_NWR/IMG_5086.MP4
The tree they nested in last year was knocked down by a storm, so they are rebuilding in a different tree about 130 meters from the road. One is not permitted to leave the road in this area of the wildlife refuge.
Nest shot looks great.  I agree.
OP's issue is likely  a camera settings, software issue (no lens profile) or other (less likely) if the lens was purchased used and had another issue.  We'll see if he replies.
In addition to lens profile, "presets" in some software will not work the same with a different camera. But this just a guess.
If the OP is in fact using histogram equalization, then that is likely the problem. But this is just a guess. I used histogram equalization 35 years ago because it does not require much computation and computers were much slower then. Now I would adjust the gamma curve or apply curves to a histogram. Histogram equalization will exaggerate the vignetting. But the biggest difference is the switch from crop sensor to full frame sensor. With the EF100-400mm f/4.5-5.6L IS II USM on EOS 70D, all of the vignetting would have been cropped. Also, the RF 100-500 F4.5-7.1 IS lens has more measured vignetting than does the EF100-400mm f/4.5-5.6L IS II USM.
Measured vignetting for this lens: https://www.the-digital-picture.com/Reviews/Lens-Vignetting-Test-Results.aspx?FLI=0&API=0&FLIComp=0&...https://www.the-digital-picture.com/Reviews/Lens-Vignetting-Test-Results.aspx?Lens=1510  Canon RF 100-500mm F4.5-7.1 L IS USM Lens Vignetting
From 2022: https://community.adobe.com/t5/lightroom-classic-discussions/vignetting-profile-correction-for-canon...
I no longer use Adobe software, but doubt that combining a lens profile with histogram equalization is a good idea.
