10-22-2016 07:40 AM
Hello.
When im filming with T4i and Canon EF 40mm f/2.8 STM during motion the picture is not smooth, look at attached footage.
https://www.youtube.com/watch?v=ESzJmqgIO0s
When filming steady shots all good.
Im not talking about shaky video - its normal , im talking about this step by step motion of picture to right.
Thank you for help.
10-22-2016 03:57 PM
I was on manual focus, so thats not the issue. After multiple tests and deeper investigation: issue is some sort of Rolling Shutter, you can see similar issue here https://youtu.be/MQCMsdhlXC0?t=1m54s
The solution in my case is downgrade video quality to 720p 60fps.
Thank you
10-22-2016 11:34 AM
I'm not sure if I am seeing what you're seeing. Do you see this issue when you play back videos in the camera? On your local computer? In fact, I don't see anything beyond some camera shake. Could there be a YouTube connection issue for you?
10-22-2016 11:53 AM
@mim23beat wrote:Hello.
Thank you for help.
What you are seeing is typical of the Auto Focus of that camera. Newer and higher end Canon cameras use the Dual Pixel AF sensor, which is much more responsive to changes in the focus distance.
Canon EOS M5 Dual Pixel CMOS AF
10-22-2016 03:57 PM
Thank you
10-22-2016 05:58 PM
@mim23beat wrote:I was on manual focus, so thats not the issue. After multiple tests and deeper investigation: issue is some sort of Rolling Shutter, you can see similar issue here https://youtu.be/MQCMsdhlXC0?t=1m54s
Thank you
Downgrade the video quality? That sounds more like a work around, than an actual solution.
But, if you're happy, then I'm happy.
10-22-2016 06:11 PM
