‎04-04-2023 06:57 PM
I just purchased a 100mm/2.8 USM Macro lens. Works perfectly on my 6D. It does not respond at all on my film EOS A2. I have three other EF lenses, 17-40 L, 28-135 IS and 70-300 IS. All of these other lenses work fine with my film EOS A2. Does anybody know why?
‎04-06-2023 10:44 AM
Battery indicator shows good and all my zooms work fine on old A2
‎04-06-2023 10:45 AM
Thanks for your thoughts
‎04-06-2023 10:49 AM
Does the camera display F/00 as the aperture in the viewfinder. Or does it display the actual aperture.
‎04-06-2023 11:50 AM
Was suspect that was the cause since lens worked fine on 6D and other zooms worked on A2. Just re-handled everything and 100mm now works good on A2. I bellive the body pins on the A2 were the culprit. Thanks
