Upgrading to Mirrorless body, R8 or comparable - Will my EF lenses fit?
ralf63
Will all of my Canon Rebel EOS EF lenses fit on the new mirrorless R8 or similar types?
Tronhard
VIP
VIP
Hi and welcome to the forum:
If you have a Canon Rebel camera, then it is very possible that you actually have two kinds of lenses:
EF lenses are designed for full-frame cameras and work perfectly well on crop sensor bodies like a rebel
EF-S lenses are specifically designed for crop-sensor (e.g. Rebel) bodies, and are not designed to work fully with full frame sensors.  In the DSLR world, this meant that they would not even physically fit into a full-frame body, but one can physically mount them on a FF R-series body, but there are limitations.
The R8 will sense that you have installed an EF-S lens and will automatically reduce the area of recording within the sensor to that of an APS-C camera because the lens projects a narrower cone of light back towards the sensor and will not fill it with an image, creating a huge vignette.  This is significant, as it reduces the MP count of the camera down by a factor of 2.56, so the full 24MP FF sensor of the R8 will render only about 9.7MP with an EF-S or RF-S lens.
Furthermore, while there are many more modern EF-S lenses out there, a lot of kit lenses, especially older ones, will not perform well on a high-quality FF sensor on the R8.
No matter what lens you have (EF or EF-S) you will require an EF-RF adapter to physically connect those lenses to an R-series body.
So, to get the most from an R8, I would suggest you strongly consider a native RF (not RF-S) lens.  You also get an optic designed to make the best use of the new sensors and other features of the R-series bodies.
cheers, TREVOR
4 REPLIES 4
March411
 EF lenses perform well on the R bodies using the Canon RF adapter. This is one of those occasions where I would strongly recommend the OEM adapter over 3rd party. I tried several and the Canon performs flawlessly while I had focusing racking with the 3rd party adapters I used on my R bodies.
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Tronhard
VIP
VIP
cheers, TREVOR
Great explanation and advice, Trevor!
Thanks Kris! 🙂
cheers, TREVOR
