02-15-2024 02:43 PM
When wanting to achieve the narrowest possible depth of field, there are several factors. Three of which are focal length, aperture, and minimum focusing distance.
What follows is a current listing of mostly RF L-series lenses (with two EF L-series lenses sprinkled in which I own):
Key: MFD (Minimum Focus Distance), DOF (Depth of Field).
Takeaways:
02-16-2024 06:27 AM
I expect that the minimum focus distance specification for a lens will be based upon someone's idea of a correct or standard circle of confusion. Depending upon how the photo will be viewed, one might be able to focus on an object closer than the minimum focus distance in the specification or may need to focus at a further distance than the specification.
Also, for a zoom lens, a single distance is usually given for minimum focus distance, but that will sometimes change when one zooms.
02-16-2024 06:37 AM
Some of Canon’s zooms do have the same MFD at all focal lengths. Others do vary. When building the list, I always took the maximum focal length and the documented MFD at that value.
One lens I didn’t mention was the RF 100mm f/2.8 Macro. I wanted to omit macro lenses as they would have a whole different level of DOF. This lens would be 0.07 cm.
