07-05-2019 11:58 AM
I have a few small (light)scratches on the outside perimeter of my 18-135mm lens. I really do not see a problem with my images. But how do i remove them. Some recommend toothpaste, others very fine sandpaper 4000 etc. If use of toothpaste is recommended with sodium bicarbonate or without, with fluoride or not etc. And some recommend a water isopropyl mixture which i tried and did not work.. Thanks for your help!!
07-06-2019 04:10 PM
Sorry ... didn't mean to rub it in! ![]()
Have you tried the lens out since? If so, how are the images?
07-06-2019 05:26 PM
trevor you did not rub it in , The canon 18-135mm lens works fine. Thanks again!!
