RF 28-70 F2 IS STM f-stop range question
Cantrell
Mentor
All,
Considering purchasing the above lens. Because there is not a range in F stops. The F2 is the F stop at 28mm as well as 70mm. Is that correct?
Thank you in advance for your response.
Greetings.
This is a constant aperture lens. meaning it can be set at f2 (wide open) throughout the entire focal range.  It's a top performing lens but note it's big and heavy.  It takes a 95 mm lens filter and is 103 mm overall.  It weighs 3.15 lbs.  It's definitely on the chunky side 🙂.
28 REPLIES 28
Anonymous
Not applicable
Correct, F-stop does not change while zooming, whether set at f/2 or f/22.
Greetings.
pcs1,
Thank you for your response. Happy Thanksgiving.
Reese
Rick,
Thank you for your response. Probably should have bought this lens instead of some others that I have purchased since buying the R6M2. Happy Thanksgiving.
Reese
When it comes to lenses, there's always one more.  😂
Happy holidays to you and your family also.
ebiggs1
"Probably should have bought this lens instead of some others ....."
No, not at all. He who has the most lenses wins! At least that's my motto. 😁 And I have a brilliant start. Seriously, I always try to find and buy zooms that are constant aperture. The only lens that I have, I use regularly, that is not a constant aperture is my beloved Sigma 150-600mm f/5-6.3 DG DN OS Sports Lens. All my Canon big three are constant aperture zooms.
EOS 1DX and many lenses.
Rick,
Thank you for your holiday wishes.I will tell my wife that you told me that it was okay to buy that lens. LOL!
Reese
ebiggs1,
Thank you for your comments about the lenses with constant aperture. I have been paying more attention to the F stop value of the lens. When I first started buying lens for the R6M2 I just looked at the range of the zoom, but after posting questions on this board and getting responses which stressed the importance of the F stop I have changed my philosophy on purchasing lens. Now the first feature that I look at is the F stop.
Happy Thanksgiving.
Reese
ebiggs1
"Now the first feature that I look at is the F stop."
It always seems to be the more costly models. 🙄
