08-24-2024
08:55 AM
08:58 AM
Can someone suggest what might be happening to the edges of my pictures? This picture was taken using an eos r6 mark ii, but I had the same result with eos r8 last week. Lens was rf 24-240. The upload makes this picture look like the whole thing is soft, but it’s actually sharp - the problem is just the edges.
had the same result from an eos r8 last week…photo taken with rf 24-240 lens.
09-21-2024 03:07 PM
I found an extensive discussion about this topic on the Adobe Community. It is, in fact, a problem in moving from V2 to V3 of the Adobe lens profile for the Canon RF 24-240mm. See: https://community.adobe.com/t5/camera-raw-bugs/p-canon-24-240-lens-profile-v3/idc-p/14834475
The fix for now is reverting to V2. Interestingly, I found the same discussion from 2021 in moving from V1 to V2 of this lens profile. The solution then, as now, was to move to the previous version. Eventually the bug was fixed in V2. This has been reported to Adobe, so presumably they will fix the V3 issue at some point.
08-24-2024 10:06 AM
Never mind…I fixed the problem
08-24-2024 10:35 AM
Glad to hear it! In case someone else comes along with the same problem, would you mind letting us know how you fixed it? That could really help someone else out in the future!
09-20-2024 04:04 PM
I recently began having the same problem with blurred borders to my photos using the RF 24-240mm F-4-6.3 IS USM. I don't notice this at the shortest focal lengths, but anything over about 40mm has this problem. My camera is an R6 MII. I purchased the lens in May, and it did not develop this problem until very recently. I don't have this problem when I switch lenses. I see short, narrow, colored lines perpendicular to the border. They remind me of color bars in a test pattern. Sometimes I see the lines around the entire border, and other times it is apparent on only two borders. Does anyone have any suggestions? Unfortunately, I have not figured this out on my own.Color bars around border
09-20-2024 09:30 PM
This is apparently a Lightroom issue. I changed the LR lens profile from the most recent V3 back to V2, and the problem went away. I see that I am out of date on the firmware for my camera. I will update that and see if the lens profile V3 works properly.
09-20-2024 10:50 PM
I have had the same issue with the current version of PS, so I would suggest it is likely Adobe's lens correction software that is the issue.
09-21-2024 10:25 AM
I am not sure I would go with LR as the problem, could be but FIRST get a new SD from a known good source and a top brand. I can't ever remember LR doing or causing that.
09-21-2024 10:27 AM
I als doubt FW is the issue unless it address updating or installing a new lens, your specific model.
09-21-2024 11:01 AM
Your lens has a zoom ratio of 10:!, the ratio of the longest focal length to the shortest FL. That puts it in the category of super zoom in my book. Super zooms are not known for having great edge to edge, corner to corner sharpness.
The best zooms have zoom ratios of 3:1 or less. The laws of physics will always prevail.
09-21-2024 03:07 PM
