RF 100-500mm image issues
Nick117
Hi all, I recently bought a 100 to 500mm for my R3, been loving it 90% of the time. Just recently, I noticed these lines appearing within the images. Inside the Red boxes. It also appears in video mode. They don't appear to show up from any other lens i have. So it seems to be an isolated issue with the lens. I don't suppose if anyone has had this issue. Or any ideas of what may be causing it. Many Thanks Screenshot 2025-08-26 at 12.09.47.pngScreenshot 2025-08-26 at 12.09.47.pngScreenshot 2025-08-26 at 12.10.14.pngScreenshot 2025-08-26 at 12.10.14.pngScreenshot 2025-08-26 at 12.41.50.pngScreenshot 2025-08-26 at 12.41.50.pngScreenshot 2025-08-26 at 12.42.03.pngScreenshot 2025-08-26 at 12.42.03.png
4 REPLIES 4
Was this lens purchased new?
I see some banding at the top of of the first image.  The lines are pronounced in the beach photo with the bird and the crop below.  My 100- 500 is sharp from the top to the bottom of the frame.  I'd say to take a close look at your sensor but if it's only happening with this lens then it's not the body.
ebiggs1
" I'd say to take a close look at your sensor but if it's only happening with this lens then it's not the body.
I would carry that a bit further and say it is the sensor. At least that is where I would focus m y investigation. Does the same irregularities show up with this lens at the 100mm side? Keep in mind as FL magnification increases so do faults and at the very same rate.
EOS 1DX and many lenses.
Peter
I have seen it from other's 100-500 at dpreview. Can't find the thread right now.
No filter?
Edit: found one here https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/Bokeh-looks-like-someone-doodled-over...
And another one here https://community.usa.canon.com/t5/EF-RF-Lenses/RF-100-500-background-distortion-Please-help/m-p/398...
Waddizzle
I used to see something similar with my 6D and a Sigma 150-600mm. Are you using any type of filter?
Are you using a tripod with lens IS enabled?
 It was only visible when I cropped in pretty far,
