08-29-2022
12:07 PM
09:13 AM
When using the RF 100-500mm lens (attached to a R5), and the lens switch is in the AF position, can you also use the manual focusing ring to override the auto-focusing? The focusing ring does have any effect when the lens is switched to AF. When using my older EF 100-400mm lens, I can use the focus ring to override the auto-focus. Is this function not available on the RF 100-500mm lens? Or, am I not doing something or is the lens defective?
08-29-2022 01:24 PM
You should be able to use the focusing ring while the AF switch is set. The lens uses dual Nano-STM motors that are not connected to a gear mechanism, so there is no issue.
08-29-2022 01:24 PM
08-29-2022 01:52 PM
Spoke to Canon's tech support and found out that on the R5 camera, in the AF menu, the "Electronic full-time MF" has to be enabled. Which was not enabled on my camera. Problem quickly solved!
08-29-2022 01:55 PM
Ah, I thought you had done that already and was asking if this would cause an issue. Glad you got that sorted.
