RF 100-500 tripod ring won't tighten sufficiently
jkphoto
I have recently purchased an RF 100-500 lens and am very happy with its performance so far.  However, the tripod ring does not seem to tighten sufficiently to prevent the lens/camera from rotating.  Any advice/solution would be greatly appreciated.
32 REPLIES 32
Interesting repair technique.  It demonstrates 2 things.
A collar that wasn't assembled properly or one that has been over-tightened causing the retention collar to slip so the cam cannot be properly tightened.
It's certainly helpful.
Canon support remains an option for in warranty or CarePak supported products. 👍
Unfortunately, I sent my lens out for the Canon warranty on the loose ring mount and got my lens back with the exact same issue right out of the box. AND got charged for not only the shipping but the 'repairs' (that was later refunded after I complained profusely everywhere I could) even though they assured me beforehand that it would not be a charged repair. I am still stuck with an expensive lens with a loose mount ring that will not tighten. It cost me $90 to ship it to them for nothing- that I had to eat- they did not pay me back for that. They told me I could send it back AGAIN, shipping on me, again, no thanks. Clearly this is an issue they are unable to resolve.
Did you try the repair in the video above?  It looks pretty easy.  I wouldn't typically recommend self repair, but its not the lens, and you've already had the collar back to canon.
The parts dept. is also a good way to go if the pads on the inside of the collar have compressed to the point that slipping occurs.
Canon Parts Order Desk
1-866-481-2569
Thank very much for sharing this workaround, I'll try to do it to solve this issue.
drac
Oh thank you all for this information. I just bought the 100-500mm for my R5 Mark II, and the collar has been slipping since day 1. No amount of finger tightening would fix it (just like the OP). I took it off and carefully reinstalled it; no more slippage. My guess is it was poorly installed at the factory (my lens had it installed OotB), and it was driving me nuts.
Hi drac,
I can't figure out how to get the collar off in the first place to try to put better felt pads in. Can you show me or point me to some information? I'm extremely hesitant to mess with it at this point without clear instructions since I've had such a bad experience with Canon repair service. Thanks so much, Tracy
March411
The cheapest  and fastest way to resolve the problem, look at the iShoot Lens Collar Tripod Mount Ring IS-RF150, Compatible with Canon RF 100-500mm, it has a 39mm ARCA quick release. Several of the folks I know, including myself have changed the OEM for this Collar and have been very happy with the swap. You can pay $90 for shipping for an attempted repair or $50 for a better overall collar.
Marc
Windy City
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Yes, I was hoping someone would post a good alternative. I have seen a couple out there but wasn't sure I was willing to trust my equipment on one. Thanks so much, Marc!
Tracy
drac
TJM,
Have you read the entire thread? I learned how to remove and replace my lens' collar from what I read in this thread. It's all there.
Your URL points at a website that doesn't work now (expired certificate). I did find the
[Link Removed per Community Guidelines]
I like the slimmer profile and how snug it fits, thanks!
