03-03-2021 04:50 PM - edited 03-03-2021 04:50 PM
Took a bunch of photos today with the UV lens. Some were fish in a shallow stream. Will be taking more this spring and summer. Got home and realized I needed a polarized lens. Ran a cross this on the Canon website. Not sure of this. Polarized insert can be removed for "regular" photos? Your advice is always appreciated.
03-03-2021 04:58 PM
That only works with a special EF->RF adapter for an R camera. You need a circularly polarized filter at the size of whatever lens you want to use it on.
03-03-2021 05:04 PM
Thanks. Found that I have one marked CPL in 58 mm. So, I'm OK.
03-04-2021 09:48 AM
You need to be really careful using that filter on your lens. It is not the strongest build lens and you can mess it up if not careful. Do not over tighten it for sure.
03-05-2021 10:29 AM
While one can overtighten any type of filter, to help against "binding", try to use filters made out of different materials.
For example, I own B+W filters which use brass. They work very well on lenses with either aluminum or plastic threads.
03-06-2021 02:20 PM
Thanks to all. Will be checking the lens with the CPL in a few days. Our Greenway runs along a creek. Try to take some photos of fish. The UV lens was marginal on fish but they didn't show up real clear.
03-07-2021 10:13 AM
"The UV lens was marginal on fish but they didn't show up real clear."
That's because that is not the job or purpose of a UV filter. Your combo has no need for a UV filter at all. Remove it as it may be hurting your photos instead of helping. Also be very careful messing with the front end of your lens. It is pretty fragile.
03-10-2021 08:53 AM
Thanks, EB. Going back to take some more photos on the Greenway. I like to experiment with the camera to get a feel for what works and doesn't work. Let me share a photo that my wife raved about. This is an unedited jpeg. Your critique is welcome. Data- 1/400, f/6.3, ISO160, 210mm.
03-10-2021 09:45 AM
If you guys both like it that's all that is important.
