02-20-2017 07:35 AM
I have a full frame 5D purchased in 2006. Have EF lenses. Looking to upgrade body. Will 5DR or 5DRs fit my current lenses?
02-20-2017 07:37 AM
Yes.
02-20-2017 08:02 AM
Thanks. Just checking before I buy because of some of the things I had read about some EF lenses not fitting in some instances. But as far as I understand it appears that if it's a full frame, it should fit a full frame.
02-20-2017 10:09 AM
"Will 5DR or 5DRs fit my current lenses?"
The fact they "fit" isn't the issue. All EF lenses will fit all EF cameras. The question is will they deliver the high level of quality that a 5Dr orr 5Ds can offer? What lenses do you currently? A camera in the class you are considering demands the best resolution lens.
02-20-2017 08:46 PM
Presently I have 2 Canon EF Redline lenses that I use the most, 24-105mm & 70-200mm.
02-21-2017 09:47 AM
IMHO, the ef 24-105mm f4 will be marginal but I bet you will see a nice improvement in your photos compared to your current 5D. I love the 24-105 but I consider it to be an entry level "L" lens. The extreme MP count of the new 5DS/5DS R are at the top end. The 5DS and 5DS R are ultra-high-pixel cameras. The 5DS/5DS R is for those who demand the very best. This means lenses, too. Otherwise opt for a Mk IV.
Which, 70-200 ?
02-21-2017 08:37 PM
The Canon 75-200 is a f2.8L. The Mark IV is stil definitely in the consideration mix, gathering facts.
02-21-2017 10:18 PM
@karlapep wrote:The Canon 75-200 is a f2.8L. The Mark IV is stil definitely in the consideration mix, gathering facts.
In your previous post you said "70-200". If "75-200" isn't a typo, it would have to be a pretty old lens. I don't think there's been one while I've been watching.
02-21-2017 11:10 PM
No, good catch. Thanks! It's a 70-200. The lens is only about 6 years old as I recall.
02-22-2017 10:38 AM
"The Canon 75-200 is a f2.8L."
This still doesn't tell me which 70-200 you have. I suspect version 1 ?
"The Mark IV is stil definitely in the consideration mix, gathering facts."
Although either camera is capable of glorious pictures, the Mk IV is a more GP model and the Ds and Ds R is a more specialized model. The vibes I am getting from you, the Mk IV is your choice.
