02-07-2023
11:46 AM
11:53 AM
Hi, all. I'm shooting the R7 with the RF 100-500mm lens. I've noticed no lens info shows up in the EXIF info. Is there a fix for this? Thanks!
02-07-2023 12:00 PM
Hey, Waddizzle. Thanks for responding. A couple of interesting things going on here. First of all, I can't import the CR3 files to DPP. So I'm opening them in Windows Photos, then right click on the photo and go to 'Properties'. All the info is there except lens data. However, if I post an image to Flickr, all the lens data is there in the EXIF file.
02-07-2023 11:54 AM
What application are using to reac the data? Have you tried using Canon’s D DPP4?
Does camera report it correctly?
02-07-2023 12:00 PM
02-07-2023 01:32 PM - edited 02-07-2023 01:33 PM
Greetings TBB,
So you are using Windows OS, hopefully something current. Are you using DPP v4.17? Sounds like a software issue.
02-07-2023 02:15 PM
Howdy Shadowsports. Yes, I'm using Windows 11. However, I misspoke earlier. I CAN view the files in DPP, but Zoombrowser EX no longer functions to automatically transfer the files from my memory card to my computer. But by copying the DCIM folder to my computer, I can then open the files in DPP and all the info is there. So, I guess it's just windows that won't read the entire EXIF file? Thanks!
