09-30-2013 09:04 PM
hello I have a Canon T2i and am going to be taking pictures of a wedding in 3 weeks... I want a better lens that can zoom in and out. Does anyone know a good one to get??
10-01-2013 01:23 AM - edited 10-01-2013 06:01 AM
10-01-2013 07:46 AM - edited 10-01-2013 07:48 AM
As asked above, what do you have now for lenses and what's your budget?
From a tiny bit of my own wedding experience (never again, though!), you'll need light, light, and light! A fast lens such as a prime (85mm might be a bit to narrow angle of view on a crop, a 50mm would be better) and an off-camera flash. DO NOT EVEN THINK of using the popup flash on the camera! The popup is too bright/too harsh on everything for the first 10 feet, then worthless beyond that.
If you'd rather go with a zoom, assuming you already have a fast prime, the EF-S 17-55 f2.8 is extremely well-regarded as near L lens quality. In some lighting situations, the f2.8 would be sufficient for no-flash photography, typically required during the ceremony. If the cost of the 17-55 is more than you can handle, the EF-S 17-85 F4-5.6 IS is also well regarded, but indoors, every shot will require a flash.
You'll definitely want a decent flash. Find one that allows you to rotate the head and can therefore be bounced off celings, etc, to minimize undesired shadows. I'm thinking a 430EX i or ii.
And don't be afraid of buying used. Both B&H and Adorama as well as KEH have outstanding reputations and have quality used equipment available. Ebay can be a good source for used equipment also, but only buy from very reputable sellers whose rating is 600 or better, with 99% rating, and has sold other high-ticket items as well, preferably camera gear.
10-01-2013 11:29 AM
My recommendation would be to leave the SLR at home and just take a point and shoot for some candids with friends. Let the professional wedding photographer do his/her job. If you’re the professional, and you’re on here asking a generic question like ‘what lens should I use’, then… not to be harsh, but, it’s a wedding.
10-02-2013 01:38 PM
This is for a friend that is not taking a no for an answer. Because she loved the pictures I did for my other friend. I just want better my self by learing more for her so that they turn out great.
10-02-2013 02:44 PM
The "bread-n-butter" lenses that most Canon wedding photographers use are:
EF 24-70mm f/2.8L USM II
EF 70-200mm f/2.8L IS USM II
Note that the first one is really more geared to full-frame bodies such as a 5D series body and not an APS-C body such as your T2i... although the lens will work (it just wont have much "wide angle" capability.)
The lens which is roughly equivalent but with a range suitable for an APS-C size sensor body like your T2i is the
Canon EF-S 17-55mm f/2.8 IS USM
This is nearly the same zoom range as your 18-55mm lens... except it's able to proivde a focal ratio of f/2.8 throughout the entire zoom range (which is 2 full stops faster or four times more light gathering power than the 18-55 f/3.5-5.6 when zoomed to mid-range or more.) It's a considerable difference.
f/2.8 zooms are not cheap, but there are lots of places that will rent them. The one major caution I'd give is that if you DO decide to rent, it's a mistake to time the rental so that the lens only shows up the day before the event. There are two risks... #1 you need time to learn to use the lens, practice with it, and make sure you're comfortable with the character of the lens before shooting something important and #2... packages don't always show up on time or undamaged. If you time the lens rental to show up merely the day before and the lens shows up broken or doesn't show up on time, you've got no plan 'b'... there's nothing they can do to rush ship a replacement. But if you time it to show up about 4 days before you need it, they can get that lens replaced and you have an opportunity to test and practice with the lens.
The alternative is to buy a prime lens (a prime lens is a lens which does not "zoom"), which are much more affordable in low focal ratios, and then "zoom with your feet". There is, for example, a 28mm f/1.8 and a 35mm f/2 lens (actually there are a few choices.) I mention these because these are "normal" focal lengths (the images from such a lens will neither appear to be wide angle, nor zoomed in... just a nice natural angle of view.) When I did professional wedding photography back in the film days, we shot the entire event with a medium format camera that had a single prime lens with a "normal" angle of view -- the shots were always gorgeous.
You can visit pixel-peeper.com to look for images taken by a specific lens. Basically they index Flickr images that have the EXIF data intact and show you sample images taken by that particular lens -- so you can see thousands of examples of what a lens can do.
As for flash, learn to "drag the shutter".
When you take a flash exposure, consider that the room itself isn't technically completely black. That means there is some ambient light contributing to the exposure. When you use the flash, you are lighting the area ahead of the camera with the flash, but flash has a "fall off" effect... the farther away the subject is from the flash, the less light they get (because light spreads out as it travels) and thus the darker the background becomes. If you take a very short exposure, then the image is lit primarily by your flash alone and very little "ambient" light from the room is collected. But if you deliberately use a longer shutter time, you still get the exact same amount of light from the flash (so that wont be over exposed) but you allow the camera to collect more ambient light.
The difference is that flash exposures on their own show a brightly illuminated subject, and a very unnaturally dark background. If you are, say, at a reception hall, the image very obviously looks like a flash exposure. But if you "drag the shutter" by intentionally setting a longer shutter exposure time, the background will fill in rather nicely with the glow of the room but your intended subjects wont actually be any brighter at all. The result is nicely exposed subject scene in a room providing a nice atmosphere -- and overall a much better looking shot.
I might use ISO 400, f/2.8 and then set the shutter speed to 1/60th even though I could take the shot at 1/200th. But that extra time pulls in a lot of the warmth of the room.
Good luck
10-03-2013 01:23 PM
Thanks for yourr help
10-02-2013 03:27 PM
Fair enough, so long as your friend understands your experience, or lack there of.
It's the wedding guest that shows up with the 5d3 and 24-70 II blasting off 1000+ shots when there's a professional wedding photographer that I have a bigger issue with.
As far as lenses, all this 24-70 II and 70-200 II is bull**bleep**. People were taking great wedding photos long before those came out. You already have a 70-200 2.8? It's fine. Maybe add in a fast prime for when it gets dark and call it good. By the sounds of it, your technique is going to have far more of an impact on your final product than whatever new equipment you get. I'd even argue that getting a bunch of new stuff is just going to give you more to worry about and possibly cost you some shots. Go shoot, try to have some fun.
10-02-2013 04:25 PM
@Skirball wrote:As far as lenses, all this 24-70 II and 70-200 II is bull**bleep**. People were taking great wedding photos long before those came out. You already have a 70-200 2.8? It's fine. Maybe add in a fast prime for when it gets dark and call it good.
I'm not sure where you were going with that comment. The 24-70 & 70-200 f/2.8 pair is pretty much the standard pairing for weddings. People did wedding portraits with 8x10 view cameras and a tray of magnesium sulfate flash powder too... but I don't recommend those for today's weddings since it's messy and tends to trigger the smoke alarms.
As the OP asked a straight up question, and those are the most commonly used lenses, you may as well give the OP the straight up answer because I think that's what they want to know.
I use the original gen I versions of those lenses because I purchased mind before the 2nd gen versions existed and there's no compelling reason to upgrade. But if I were buying the lenses again today and the gen I lenses are pretty hard to find, I'm sure I'd be buying the gen II lenses.
I did my weddings with a single 'normal' prime lens on a medium format camera (Hasselblad 500 CM with 80mm lens) and I _really_ liked the result. In many ways, a single prime lens has an advantage especially when it comes to manual flash. Subject framing in the lens was an excellent indicator of subject distance which could be used to set the f-stop when using manual flashes. With a zoom lens you don't necessarily know the subject distance becasue the zoom changes the angle of view.
The main thing is: The church, synagogue, temple, etc. will almost certainly be poorly lit. Unless this is an outdoor wedding, you'll want a lens with a low focal ratio. That's where the 70-200mm f/2.8 comes in. Using flash during a ceremony is almost universally frowned upon (you can use flash anytime before or after... just not during.)
Reception halls are also generally dark -- they deliberately dim the lights after dinner for dancing and celebration. The telephoto zoom lens isn't so necessary there and of course you can flash use flash.
10-03-2013 11:28 AM
@TCampbell wrote:
@Skirball wrote:As far as lenses, all this 24-70 II and 70-200 II is bull**bleep**. People were taking great wedding photos long before those came out. You already have a 70-200 2.8? It's fine. Maybe add in a fast prime for when it gets dark and call it good.I'm not sure where you were going with that comment. The 24-70 & 70-200 f/2.8 pair is pretty much the standard pairing for weddings. People did wedding portraits with 8x10 view cameras and a tray of magnesium sulfate flash powder too... but I don't recommend those for today's weddings since it's messy and tends to trigger the smoke alarms.
You're really arguing that the mark I isn't sufficient for a beginning wedding phographer? And that's stretching the term, it sounds like someone learning the art who's friend asked them to take pictures at their wedding.
And your analogy is crap, the difference between that and the magnesium, is that the Mark I are still capable of producing shots of a quality reflective of modern day photography.
Yes, the OP did ask a straight up question, and as usual, you ignore it. You two seem to always gloss right over peoples monitary concerns... see where they mentioned the $1000 limit? The lenses you suggested would run close to $5000. But you gotta have the best, right?
