11-16-2014 07:33 PM
I am thinking of buying a neutral density filter lens for my EFS kit bought in December 2010.
I think I need to get a 58mm lens, but there are many sizes for my camera. Which size should I buy?
11-16-2014 10:12 PM - edited 11-16-2014 10:16 PM
Hello, I have 2 lenses that have a 58mm ring size,
70-300mm IS USM & 18-55mm
I have 3 different ND filters however I tend to use a CP (Circular Polorizer) more than any other filter, I shoot a lot of moving water shots and utilize the ND 0.3 0.9 & 1.2 filters, but still prefer the F32 and the CP filter, my advice would be to look for a Tiffen kit that has the same three I mentioned, usually arond $45 US on Ebay, my philosophy is to start basic and then spend the money on a filter you like the most, the quality varies from manufacturer to manufacturer as well as the price, you can pick up a CP for $20, which gives you a quasi varible ND effect, you can spend serious money on a variable ND filter, however from what I have seen the effects are incredible.
The size of your filter ring can be found by looking up your lens here
http://camerafilters.net/eos_lenses_camera_filters.htm
11-16-2014 10:52 PM
Thanks for the information. I'll check it out.
