06-20-2020 02:03 PM
Will these two accessories work together? I've already got the lenses and filters, thinking about adding some hoods.
Thanks!
06-21-2020 10:33 AM
"Will these two accessories work together? I've already got the lenses and filters, thinking about adding some hoods."
To give you an accurate answer I really need to know exactly what filters, lenses and hoods? Beyond a polarizer and protecto filters, there is really no good reason to use filters any longer. Lens hoods on the other hand are almost mandatory. Of course there will be times when you don't need a hood but usually a good idea. A lot of people seem to forget the fact a filter or hood removes as easily as it went on. Don't need it, remove it. Simple?
For a general purpose amateur any good quality clear or UV filter will do a good job of just protection. Less than ten bucks most of the time. If you are a serious photographer that wants only the best photos you need top level clear protecto filters like the ones made by B+W. But you must weight if the filter is worth it. For instance it makes little sense to put s $50 dollar top of the line professional protercto filter on a 50mm f1.8, $99 dollar lens. Make sense?
06-22-2020 11:15 PM
Filter VS Post-processing...
Interesting conversation, coming from my father's darkroom in the early sixties, I wonder if he would ask the question...
At what point does it cease to be a photograph and become a digital painting?
06-23-2020 09:45 AM
My concern was mainly with clear glass protective "filters," not image-altering stuff. I have yet to find an image-altering filter I have any use for.
06-23-2020 12:38 PM
@Dedeye wrote:My concern was mainly with clear glass protective "filters," not image-altering stuff. I have yet to find an image-altering filter I have any use for.
I almost always use a lens hood. I always use a protective filter, too, B+W XS-Pro Clear MRC-Nano 007 Filters. A filter is much safer and easier to clean than a front element.
06-23-2020 03:06 PM
