05-28-2015 03:43 PM
Help....Canon ef 24-70mm f/4l is usm lens vs 24-105 f/4l is usm?
I shoot a lot of barns and landscapes. Not sure if I should upgrade from myCanon EF-S 15-85mm f/3.5-5.6 IS USM Lens .
05-28-2015 04:29 PM
Here is a site I rely on for lens reviews:
http://www.the-digital-picture.com/
05-28-2015 05:02 PM
05-29-2015 10:49 AM - edited 05-29-2015 10:50 AM
Liz22012,
I really hate those reviews. I suppose you can read them for funsy but they tell little on how a lens will perform in the real world.
The best recommendations are from people that use the product without an ax or agenda. (Paid by a sponser.)
For what it is worth, my accessment of the EF 24-105mm f4L IS, it is the best buy in a Canon lens there is. It may be the best lens you can buy period if you are going to have only one. Couple that with the fact you may be able to find a 'white box' version. It will be far less than the full retail price and is the exact lens with full Canon waranty. They are also great lenses to buy on the used market.
I will assume you have a crop body camera since you indicated you have the kit lens. The EF 24-105mm f4L IS will not be quite as wide as your lens. But it will have much more reach on the tele end. Sorta give to get.
Make no mistake the EF 24-105 f4L IS is a full on professional lens in every spec.
05-29-2015 03:21 PM
05-29-2015 03:38 PM
You may find that the 24mm end isn't wide enough for you.
I suggest you set your current lens at 24mm and try some shooting? Is it OK or do you want wider? Deciding between 24-70 or 24-105 would be futile if you really want a 15 or 18mm wide end.
"L" lenses are great; I have several of them. You generally can't go wrong purchasing one, particualry the zoom versions. But, depending on your end use you may not need to features of an "L" lens? Are you printing large prints or are you sending digital files to a digital picture frame? Are you getting the quality you want from your current lens? Where is it holding you back?
You may be better served by getting the Canon EF-S 10-18mm wide angle and pair it with your current lens.
05-29-2015 03:51 PM
05-29-2015 03:55 PM
Or better yet, pair the EF-s 10-22mm with the EF 24-105mm. Now we'er talking as this is about as good as it gets.
Do you ever shoot HDR? The photo below is an HDR shot with a 24mm lens. Does it look like it will work for you?
05-29-2015 04:28 PM
05-29-2015 04:44 PM
