03-24-2022 06:03 AM
As the title states I have a 24-70 ef mount that I used on my old 5D. I bought a R5 and have been using the adapter to use the ef lens, Was thinking about dumping the 24-70 for the 24-105 to get something lighter that I can use without the adapter, and take advantage of that extra focal length. Don't really care about the extra stops I would be loosing. I was just traveling/shooting and realized I wanted an easy lens to run around with that seemed pretty utilitarian, and felt a little bit better in hand.
Thoughts?
03-24-2022 12:29 PM - edited 03-24-2022 12:44 PM
I have no experience with RF 24~70 vs. RF 24~105, but as far as EF goes, the 70 is the declared winner for overall clarity and sharpness between it and the 105. When I go mirrorless, I will grab the RF 24~70 f2.8 since it now has IS. This is a walk around lens for me.
I find that the extra stops matter. I can walk inside or outside and fully utilize the faster lens when I need to shoot indoors with no flash. I am a landscape and architecture shooter so the stops matter to me. (Cathedrals, Museums, insides of castles)
The RF24~70L is twice the cost of the F4 for a reason. But don't let what I would do make your decision. I'd be willing to use my heavy weight Siggy with an adapter on a R5c (no ibis) in a pinch over getting a RF~105 F4, but thats just me. An RF 105 F4 has IS and your R5 has ibis, so you'll get great results (hand held video), but if you walk into a dark space, you may not be able to shoot without flash.
If you are going to spend the money, and sell your EF lens, you can offset the purchase of the 24~70, but again, thats up to you.
Others will be replying shortly.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
03-24-2022 12:32 PM
Sounds like a go to me. A bit more reach and a bit lighter and smaller and best of all no adapter. I don't like adapters either. But for me there is no way I will ever give up my ef 24-70mm F2.8L lens. I love it and use it constantly.
03-24-2022 04:15 PM - edited 03-24-2022 06:51 PM
WHAT PRICE VERSATILITY?
I'm rather in the opposite situation to Rick: I have had both the EF 24-105 f/4 MkI and the new RF version of the same lens, but I don't have the 24-70. I do agree with Rick and Ernie that the EF and RF versions of the 24-70 are highly lauded, however the RF 24-105 f/4 is no slouch and is markedly better IMHO to the EF version.
In the end though, you need to choose the characteristics of the lens that will work for you, and there is more to it than pure image quality, especially if you need versatility. The list of considerations include:
1) What is your budget? Cost can be a big factor, but possibly less so in your case.
2) What kind of photographer are you? Professional, semi-pro, enthusiast, student, casual, purely social - professionals will require the ultimate in performance but will pay for that in cost and extra kit.
3) What subjects do you shoot? Gives an idea of the focal ranges you need - it appears that you want a walk-around unit for a wide range of subjects without other lenses - so that implies a wider focal range.
4) What do you produce? digital media, small prints, large detailed images - the latter require better quality images the former not so much.
5) What are you prepared to carry? In your case, travel suggests reducing weight and bulk, and with a wide focal range without changing lenses.
It would be helpful if, in giving advice, we all say what each of us uses and how we use these lenses, as that is a significant consideration - it speaks to how those factors above are weighted when giving and assessing advice and its applicability to your situation. Speaking for myself, I am in much the same boat as you, EB. I prefer lenses that cover a bit more focal length, find f/4 to be fine, and do a lot of travelling (under normal circumstances). I have a couple of the RF24-105 f/4 units, plus a RF24-240, and find them to be very appropriate for my needs - I find the RF 24-240 is a very underrated lens, and no slouch for it's intended purpose of travel and general photography.
To get a fairly good comparison between it and both versions of the RF24-105, I recommend the following unbiased and detailed review by the respected reviewer Gordon Laing from Camera Labs: HERE, as it shows the 24-240 as no slouch for resolution, and the results about corner resolution are surprisingly to the benefit of the 24-240! There is a second in detail review of the 24-240 from Justin Abbott HERE. Justin Abbott commented on the tracking limitations with the R and RP. I am using the R5 and R6 and their tracking is massively superior to those earlier bodies, a demonstrated by some of the images below.
As regards to image correction: the 24-240 appears to shoot at its widest angle at an actual 21mm, but uses in-camera and post-processing correction to give good results at 24mm. You will not see those issues through the viewfinder: all corrections are done in camera to the display and to the JPGs. PS and LR do corrections to RAW via lens profiles upon loading images. This kind of software image correction is becoming more of a hallmark of lenses, especially those of wider focal ranges and it is effective. Tamron just released the rather amazing XF18-300 for the Fuji X-mount, and it uses similar software corrections to significant effect. The days when super wide zooms rendered very mediocre results are changing in some of the new technology out there.
So, sticking to the theme of versatility, here are some images shot, all hand-held, using the 24-240 at a wide range of locations and conditions to demonstrate the abilities of a lens that concentrates on versatility without losing too much quality yet still show that the lens does an OK job IMHO.. Note that my images have had to be drastically reduced to fit into the 5MP limit for the site, so I recommend that you expand them to full screen size to view.
A local gannet colony - sea mist on the coast. First, at the wide end on the R5, 28mm, f/10, 1/400sec, ISO-200
Fast focus and tracking: Canon EOS R5, 240mm, f/7.1, 1/640sec, ISO-200
Canon EOS R5, 140mm, f/7.1, 1/1600sec, ISO-200Now on the EOS R6, 240mm, f/9, 1/500sec, ISO-100
To show images that are more for an urban environment, here are a couple from the celebration of Matariki - the Maori New Year.
Showing no distortions: Canon EOS R6, 24mm, f/5.6, 1/80sec, ISO-400
People photography: Maori Poi Dancer in action: 50mm, f/4, 1/240th sec, ISO-200
Maori Concert Group: R6, 24mm, f/8, 1/200sec, ISO-200
I went to the local museum and shot in very available light the highly-detailed image of a Maori whare, or building - this one is actually for storing food. The light was extremely dim and I had to shoot hand-held.
Canon EOS R6, 61mm, f/5, 1/13sec, ISO-1600
Detail quality: The same image at 100% crop:
Finally, a shot out of my study window of a Pohutukawa shrub, in the garden right outside with a roaring gale blowing - through a slightly grubby double-glazed window.
First the full frame, reduced in size 240mm, f/6.3, 1/400sec, ISO-250
Now the same image at 100% crop. Point of focus was the buds just in front of the bloom
In showing the versatility of this lens, which I am aware you have not considered, I am not trying to discredit the opinions of my respected colleagues, but I am trying to make the point here is that much depends on how and what you are going to shoot, and very much on what you are going to produce. These images, showing the versatility of the range, when not so drastically reduced in size, have been printed effectively 18"x24" without issue and could go bigger if needed.
One thought is that you could keep your EF 24-70, which you acknowledge works well and given you would likely have to pay a hefty upgrade price to get the RF 24-70, instead purchase the RF24-240 for the versatility and have the best of both worlds possibly for the same cost or not much more than getting an RF 24-70.
03-24-2022 11:16 PM
Trevor,
Marvelous doesn't do your images the justice they deserve.
03-25-2022 10:43 AM - edited 03-25-2022 10:44 AM
"Trevor,
Marvelous doesn't do your images the justice they deserve."
Plus 2! 😁
03-25-2022 02:41 PM - edited 03-25-2022 02:44 PM
Thank you Ernie and Rick, as highly-respected colleagues on this forum, your comments are much appreciated.
I simply post the images to indicate what I can get out of this lens - some will likely get more, some less: but it certainly shows that the lens is versatile without being unacceptable for many applications. I had not intended to get the 24-240, but when I got my R5 and R6 bodies, the 24-105 f/4 was on back-order (it took 5 months to be delivered to me). So, to keep things going at the lower end (I did have the 100-500), I got the 24-240, and was immediately surprised by how much better it was than I had expected, and it certainly is versatile.
I was surprised how sharp the RF24-240 was compared to either of the RF24-105 variants. I put this down to the serious software involvement in tweaking the images that the 24-240 had but the others did not. Imagine what the others could do if they had similar treatment...
03-26-2022 04:17 PM - edited 03-26-2022 04:19 PM
Comparing the RF 24-105 f/4 with the RF 24-240
I don't have a copy of the RF 24-70, but I do have samples of each of the lenses above, so I decided to try a bit of a comparison of their performance with a series of images of the same subjects, taken from the same vantage points and with the same settings (according to the lens controls). They were both attached to identical R6 bodies, configured in the same way, using Av mode with auto ISO.
This was done in the precinct of my local museum, to test the abilities of the lenses to work within the challenging constraints of enclosed buildings and limited light. Being a museum, tripods are not allowed, so the images are hand-held and thus alignment might not be absolutely perfect. That said, the images provide some interesting comparisons. In all cases, standard lens correction is applied - considering this is done automatically, it seems most aligned with a real-world scenario and is the same methodology applied by DPReview and other lens reviewers.
First both lenses set at 24mm, Portrait of the straight lines of architecture.
Canon Rf 24-105: 24mm, f/6.3, 1/60 sec, ISO-500
Canon RF 24-240, 24mm, f/6.3, 1/80sec, ISO-250
Comment: the Fields of View are quite similar (thanks to the lens corrections) and generally they look reasonably similar, which is what one would hope for. I found it interesting that the cameras used different shutter speed/ISO combinations for the same aperture. I speculate that this has something to do with the different element configurations of the two lenses. Still, the results seem very similar.
Next a Landscape shot of a display at 24mm
This time, showing elements at close to medium distances and evaluating the colours and tonal values. I must admit I didn't get the vertical alignment quite the same, but the horizontal values are reasonably close.
RF24-105: 24mm, f/6.3, 1/15sec, ISO-1600
RF 24-240, 24mm, f/6.3, 1/4sec, ISO-250
Again there are variations in shutter speed and ISO values, yet the images again appear to be very similar
This is a comparison of images with a focal length of 50mm.
RF 24-105, 50mm, f/6.3, 1/15sec, ISO-1600
RF 24-240, 50mm, f/6.3, 1/2sec, ISO-250
Again, apart from slight compositional variations, the coverage, tonal values are not dissimilar and the corrected lens characteristic are comparable.
Finally at 105 mm (or as close as I could get)
RfF 24-105, 105mm, f/8, 1/40sec, ISO-1600
RF 24-240: 106mm, f/6.3, 1/10sec, ISO-250
I forgot to change the aperture of this last shot, but with a lot more light it is a bit less significant.
SO... that is a rough comparison of the performance of the RF 24-105 f/4 and the RF 24-240 f4.0-6.3.
Comments welcome
