Filters vs Lens Performance
bento2
Enthusiast
Iv'e seen many posts on the internet regarding effect of filters on the Canon 100-400 L zoom.
Will a Canon clear protector filter really degrade my lens?
Thanks
20 REPLIES 20
hsbn
Whiz
Any extra piece of glass will degrade your lens, just good filter doesn't affect as much. Personally, I have never used protective filter unless in really harsh condition.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
cuda719
Enthusiast
The bigger question can you afford to replace the lens if you accidently scratch the front element without a filter.
Spend a little money to protect your investment with a quality filter. Such as B&W
There is no need to replace the entire lens if you should accidentally scratch the front element.  It depends on the lens, but it may cost as little as $250 to change the front element on a $1500 lens.
For me it just seems crazy to spend up to $100 for a piece of glass to protect a $250 piece of glass. Especially since "Protection" filters are notoriously fragile and prone to scratches. Over time the filter will need to be replaced as they don't stand up to multiple cleanings as well as the front element of a lens.
All those photos of smashed filters "Protecting" their lenses are really just evidence of how poor a job they do at protection. Often the slightest bump will shatter the filter into tiny pieces that get everywhere and are a pain to clean up afterwords.
Photos of smashed or cracked filters
Mike Sowsun
"...  but it may cost as little as $250 ..."
And it "may" cost quite a bit more!  Smiley Surprised  Plus not to mention the hassle it is to box it and ship it.
Not everybody lives next doot to a repair facility.  Now we are talking time down, too.
Sometimes one of my "protection" filters has moved from lens to lens, so your $100 filter now costs me $50 bucks or less.
Why do you people not understand a filter is 'removable'?  It comes off as easily as it went on!
If a situation warrants it, take it off.  Otherwise, it is good protection even if only slight protection.
EOS 1DX and many lenses.
Skirball
The 100-400L has 17 elements inside that the light has to pass through to get to the sensor.  The majority of these are precisely curved to allow proper redirection of light while minimizing signal loss.  Would you have not bought the lens if it happened to have 18 elements?  A simply flat piece of glass is trivial in manufacture and design compared to the elements inside the lens.  Aside from ghosting issues, I haven't seen any convincing evidence that UV filters noticeably degrade the quality of the final photo.  Using a filter is a personal choice.  To me, it's worth it, considering low cost and negligible IQ loss.
100-400
But if you treat your camera/lens well, you should not have to worry about scratching it. I'm really clumsy when it comes to camera gears. But for 16 years, I have not scratched any lens. The reason that I don't use UV filter because I use polarizer a lot. If I stack polarizer on top of UV, it would be too thick :D, not because afraid of a little lost of IQ.
Quote:
"Why do you people not understand a filter is 'removable'?  It comes off as easily as it went on!
If a situation warrants it, take it off.  Otherwise, it is good protection even if only slight protection."
I think the OP was wondering specifically about using filters with the Canon 100-400 as there are lots of stories all over the internet about people complaining about softness with the 100-400 that went away once they took the "protection" filter off.
To answer his question, yes, according to the many stories I have read, ANY filter on a 100-400 wil cause softness and/or focus problems.
Mike Sowsun
I suppose it's possible.  The engineer in me is sceptical, as I can't imagine physically what would be any different than any other focal length.  But you never know.  If you get sharper images without a filter, then by all means don't use one.  Who cares if it's placebo if it's working.
