12-03-2024 09:13 AM - last edited on 12-12-2024 11:51 AM by Danny
Looking to take better photos with my EOS RP - the lens I currently have is 24mm - 105mm looking for opinions on lens that wont break the bank that would enable more distance photos I am a novice and would appreciate any lens guidance. Thank you !
12-03-2024 10:26 AM
Look into the RF 100-400mm zoom.
12-03-2024 10:26 AM
12-03-2024 01:06 PM
Thank you !
12-03-2024 11:39 AM - edited 12-03-2024 04:41 PM
Absolutely look at he RF100-400 ($650 US), it's light weight and has good range. I carry this lenses for extended periods hiking, is hardly noticeable and takes great images. Another option would be the RF24-240mm F4-6.3 IS USM ($800 US).
The image is in a fairly densely forested area on an R6 MKII with the RF100-400.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
12-03-2024 01:05 PM
Beautiful photo Would this lens need an adapter for my camera ?
12-03-2024 02:02 PM
jrhoffman75 suggested it because it is an RF mount which is what your RP uses so no adapter. I was simply agreeing with his suggestion as it was in line with your desire for more range. Personally I love this lens as an all day carry, it focuses fast and has real nice image quality for a very aggressively priced lens.
Be aware this lens is not super fast and needs light. It will be a bit challenged indoors, early sunset and sunrise. That being said, the image I posted was pretty low light so you can still capture some real nice frames if you know the lenses limitations.
If you decide to go this direction do the membership a favor and tag jrhoffman75 suggestion as a solution. Other members searching the forums can easily find a answer to a similar question.
Personal Gallery
