EF 75-300mm Lens Attachment Problem
wjcarney1975
I have a EOS Rebel T3 along with the EFS 18-55mm lens and the EF 75-300 lens.  Recently the EF 75-300 lens has stopped attaching properly to the camera while the EFS 18-55mm lens still attaches fine.  I don't see any damage to the lens but thought I would check and see if anyone else has run across this problem?
Thanks!
Bill
7 REPLIES 7
Mark35mmF2
One thing I would suggest looking into specifically are the screws on the silver lens mount. If one of those screws is loose it may be protruding enough to cause an issue. you can lightly tighten these screws with a small phillips head screwdriver. Otherwise, the lens might need service to address something else with the mount.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
Thanks very much, I'll check those screws out!
Bill
ebiggs1
Was the lens dropped? It wouldn't take much to make the mount a bit out of alignment.
EOS 1DX and many lenses.
Thanks so much, upon further investigation it turns out my son did drop the lens so it must have gotten misaligned somewhere.  Do you know if canon still services that lens?  Thanks!
This is a cheap and cheerful kit lens of, at best, meadocre quality. It is not worth servicing: either ecomomically or quality-wise.
I would suggest replacing it with thee excellent. EF-S 55-250 IS STM or, if you ant the reach and are ptepared to invest a bit more, the excellent. EF 70-300 IS USM  lenses. Either the Mk1 OR 2 versions are great lenses. See my review of them Here
cheers, TREVOR
Got it, thank you!
Suggest you keep an eye on the Canon refurb lens site at This Link
cheers, TREVOR
