12-29-2020 11:21 PM
First post to this board. HELP!!!! I have the EF 70-200 mm f/2/8L IS III USM lens, purchased 7/2019. When I say it is minimally used, probably used not more that 8-10 times. It has not been mishandled whatsoever! Something has happened and it is not auto focusing. I put in the repair for an estimate and it was right around $400.00. Before I send it in, I thought I might get some suggestions as to what might have occurred to cause this. And is there anything I might check on the lens or in camera. Nothing appears to be wrong with the lens settings. Suggestions please!!
12-30-2020 12:32 AM
Welcome!
There's an "AF-MF" switch on the lens. Since you have not mentioned about it, could I presume it's set on AF ?
12-30-2020 10:26 AM
"...could I presume it's set on AF ?"
Yes because the OP said,... "Nothing appears to be wrong with the lens settings."
12-30-2020 12:59 PM
Okay, if the lens switches are good, then I assume that means both AF/MF and focus limiter switch are good.
What about other lenses? Can you auto focus with other lenses, too? Is the camera set for BBF?
