12-22-2020 06:06 PM
I want to complement my R equipment. I have the EOS R and may follow. I need sometimes more than 24mm and bokeh isn't an issue.
The Samyang AF14/2.8 may be a good option. But I can't mount a filter. I photograph often in harsh conditions, e.g. constructions aereas.
My second thought: can the EF 17-40/4 L US or EF 16-35mm/2.8 L USM II image quality keep up to the R/R5?
My last considaration: the EF 17-40/4 L US is cheaper than the EF 16-35mm/2.8 L USM II and maybe a cheap substitute until another options ar available. I hope that Sigma or Tamron launch a soon a similar lens. Or Canon comes with somethng affordable in the range of 15 to 18mm.
12-22-2020 07:21 PM
You have an RF mount body. You should only consider RF mount lenses, especially if you are considering an R5.
12-24-2020 10:35 AM
"You should only consider RF mount lenses, especially if you are considering an R5."
This only makes sense. And, stick with Canon unless there is no Canon to consider.
12-24-2020 06:17 PM
The typically reliable Canon Rumors has recently stated, in no uncertain terms, that Sigma will begin making RF mount lenses in 2021. Hope it's true.
12-29-2020 11:34 AM
