04-16-2025 03:45 PM
I am currently learning about my R8 and am using it with an EF adapter so I can take macro shots with my trusty old EF 100mm f2.8 macro lens. Today, it did something weird in Manual Focus mode: It would not let me focus! The focus ring turned, but the internal elements did not keep turning. When I switched to AF, it found the focus - and then the MF mode worked!
Has anyone seen this behavior? Is there something I'm missing that's causing this?
Thanks in advance for any suggestions...
Jim V
04-17-2025 09:14 AM
Which version of the EF 100mm f/2.8 Macro do you have?
04-17-2025 10:09 AM - edited 04-17-2025 10:09 AM
Mike - Ooops! Yes, I should have included that it’s an L series lens…
Jim
04-17-2025 11:02 AM
"...using it with an EF adapter ..."
Also which adapter. It can make a big difference.
04-17-2025 11:35 AM
Like other USM L lenses, the focus ring is Full Time Manual Focus, and should always be directly connected to the focus mechanism. Using an adapter should have no effect on Manual Focus. If the problem re-appears, you might need to service the lens.
04-17-2025 01:01 PM
The adapter is the “Canon Mount Adapter EF-EOS R” product 2971C002.
Jim
04-17-2025 01:03 PM
Mike - When you say “…the focus ring is Full Time Manual Focus…”, may I assume you mean that even if the focus switch on the lens is set to Autofocus, turning the ring still changes the focus?
04-17-2025 01:09 PM
Gah!! Adding to the mystery, I tried to repeat the “stuck manual focus” problem and now it works just fine. Swell.
Any thoughts? Has anyone seen this before?
04-17-2025 03:12 PM
Yes, even when set to Autofocus, the focus ring will always be directly connected to the focus mechanism with “Ring Type” USM lenses. Micro USM and Nano USM are 2 exceptions.
