02-10-2018 05:25 AM
Hi! To my Canon EOS 1000D need new lense for photografing dogs, their portraits and activity (jumping, playing, running).
Perhaps I want to much
...2 in 1... will be grateful for any recommendations, price level below 1000
02-11-2018 10:31 AM
Even if you do not upgrade your camera you want the Canon EF-S 17-55mm f/2.8 IS USM Lens. But I would seriously consider upgrading the camera too. However, that lens will make a huge better difference for you.
02-10-2018 09:25 AM
What lens do you currently own, and why does it not work for you?
02-10-2018 10:28 AM - edited 02-10-2018 10:35 AM
@Finka1 wrote:Hi! To my Canon EOS 1000D need new lense for photografing dogs, their portraits and activity (jumping, playing, running).
10 yr old camera... 10MP and Digic III.
Even with a budget of $1000 or less you could get a nice bundle. Something more current to build on.
Edit - Don't get me wrong.. I love "classics" but a 1000D isn't classic and the amount of technolgy that has ocurred since makes upgrading worth considering.
02-11-2018 10:31 AM
02-11-2018 01:18 PM
@ebiggs1 wrote:Even if you do not upgrade your camera you want the Canon EF-S 17-55mm f/2.8 IS USM Lens. But I would seriously consider upgrading the camera too. However, that lens will make a huge better difference for you.
The lens Ernie recommends is a fine lens; my wife and I each have one. But don't imagine that you can use it with the camera's built-in flash. Even on cameras larger than the 1000D, it will cast a large shadow in the camera's coverage area.
03-05-2018 02:03 PM
Which camera you have to Canon EF-S 17-55mm f/2.8 ?
03-05-2018 04:23 PM
@Finka1wrote:Which camera you have to Canon EF-S 17-55mm f/2.8 ?
We've used ours on T2i, 7D, and 7D Mark II. I may have also used mine on my 50D a few times; I don't recall for sure.
03-05-2018 05:05 PM
"But don't imagine that you can use it with the camera's built-in flash"
It isn't worth using anyway so it is a moot point.
