11-05-2024 04:44 AM - last edited on 11-05-2024 08:05 AM by Danny
Totally new trying to buy gift for loved one. If I am buying the s18 - 150mm f3.5-6.3 is stm lens kit do I need the f/1.8 stm lens or is that covered in the kit range? Is there a benefit to having both? Thank you! - R
11-05-2024 04:52 AM
Are you planning on buying the camera and lens as a kit? If so, that's a great kit lens for the EOS R10, EOS R7, EOS R50 cameras. If you want to get the RF 50mm F1.8 STM lens too, then it is covered in the zoom lens as 50mm is in between 18 and 150mm. However it is a small compact lens that is good for low light portraits. It might be a little overkill depending on how experienced the loved one is with photography.
11-05-2024 05:24 AM
Hi, and welcome to the wonderful (and sadly rather complicated) world of interchangeable-lens photography.
Your question as posted is, unfortunately, not really in a state where it can be answered. So I'll try to help you with the basic concepts here a little, and maybe you can post a clarification, and we can give you a more definite answer. OK?
But first -- please don't post the same question twice; that's only going to cause confusion. It would be better to go back and delete the other post.
So. There are two main factors about a lens that matter -- the focal length (which determines the width of the field of view; you might think of this as "magnification"), and the f-number, which descrubes how bright a lens is (basically how physically wide it is, and hence how much light it catches; smaller f-numbers indicate a brighter lens). In your case, 18-150mm is the range of focal lengths covered by a zoom lens, and f/3.5-6.3 is the range of brightnesses is has -- meaning it is as bright as f/3.5 maximum, when zoomed out, and less bright -- f/6.3 maximum -- when zoomed in. (This is very typical for budget zoom lenses.)
So to some points where we could use more clarification:
The simple answer is that the RF-S 18-150mm f/3.5-6.3 zoom lens is a great beginner lens for a camera with an RF-S lens mount, covering a huge range of focal lengths, so that it would be a fine starter lens all by itself. It seems to get decent reviews, based on its low cost: https://www.digitalcameraworld.com/reviews/hands-on-canon-rf-s-18-150mm-f35-63-is-stm-review
(For a camera with a different lens mount, it might be not so good, or it might not work at all; but if it's a kit lens, it should be fine.)
The main drawback is that it's not very bright; f/3.5 at the wide end, and f/6.3 zoomed in. An f/1.8 lens would be quite a lot brighter, but without knowing the focal length, I can't say what it would be good for. And in outdoors, daylight shooting situations, the extra brightness might count for nothing -- the fact that a lens can open up to super-bright is pointless if you never actually need the extra light.
Dooes that help?
11-05-2024 12:34 PM - edited 11-05-2024 12:37 PM
It may help everyone a little to know the camera body for this lens. Also, It all depends on what a person intends on photographing and what they want to achieve in their images.
The f/1.8 is a faster (brighter) lens and will allow you to capture more light when shooting at f1.8. It also gives you improved control over depth of field, and the ability to create a nice bokeh (blur) effect in your images if that is your goal. The faster f1.8 aperture will also allow you to photograph in low light without having to push your ISO up as much as your f/3.5-6.3.
Opinions vary, personally I always attempt to purchase the fastest lens within my budget. With noise reduction software doing an excellent job these days some say it is better to purchase a slower lens and let the software do the heavy lifting.
Really nobody here can tell you which one is better for you given the fact none of us know your photography style. We can offer some insight to help you decide which would work best for you.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
11-05-2024 07:26 PM
Canon R10 and it will be some nature photos but a lot of a toddler indoor and outdoor. Starting to understand a lot better now. Appreciate your response and everyone else’s so far!
11-05-2024 08:07 PM - edited 11-05-2024 08:15 PM
Canon R10, that works. It has an APS-C (crop) sensor @ 24 MP.
For indoor photography you would be OK with the lens @ 18mm f3.5 but once you starting to zoom the lens would be starved for light. Fully zoomed @ 150mm - f6.3 would be challenging unless you use flash. Outdoors, most days you would be alright, early morning, twilight and overcast skies could create some challenges.
The RF-S for Canon does not offer a lens that is fast, with time that will probably change. Here's where it gets fun, you can use the RF lenses on your R10 but you need to multiply the focal length of lens by 1.5 to calculate the equivalent focal length of a lens. What does that mean? If you mount a 50mm RF lens on on your R10 camera you will achieve the same view as a 75mm lens on a full-frame camera.
So it you are looking for a fast lens for indoor use and you have a budget you are still in great shape. As an example, the RF24-105mm F4 L IS USM ($1300) is a fix aperture but would be better indoors even if you were to fully extend the lens. Here's how the zoom length would be affected:
Another advantage would be that this lens has Optical Image Stabilization at up to 5 Stops* of Shake Correction. Since you body does on have stabilization this would be a bonus especially when bouncing around taking pictures of the toddler.
I'm not suggesting this lens, it was just a good example. And back to your original question, do you need one? If you can justify the expense and will get a use out of it..... your call. It's easy to fall into a trap buying a lens because you think you need it and then it collects dust. Use the one you have for a bit, if it falls short then the easy answer is yes you need it and then what focal length will give you the most bang for your buck.
Good luck and enjoy the new hobby!
Personal Gallery
11-06-2024 10:23 AM
" If I am buying the s18 - 150mm f3.5-6.3 is stm lens kit do I need the f/1.8 stm lens or is that covered in the kit range?"
Your question doesn't really make any sense. Lens aperture and focal length are different specs. Aperture like f1.8 refers to how fast a lens is. The mm refers to the focal length of a lens. Manufacturing a 18-150mm f1.8 lens would be expensive, heavier and larger. Now if you are asking if you need to add a lens like the 50mm f1.8, then the answer is probably not. A lens like the 50mm f1.8 is a specific use lens nowhere nearly as useful as your zoom. But if your situation calls of a prime lens like it, nothing else will do.
11-06-2024 01:02 PM - edited 11-06-2024 01:04 PM
Hi and welcome:
Buying gear for a photographer is fraught with challenges, especially if you are not knowledgeable in photography and the specific styles of shooting your relative applies. You run the risk of expending money on a lens they don't want or need and puts them in the position of either asking to change it or suffering along to make you happy.
Rather than taking the decision on a specific optic yourself, I would recommend taking them on a shopping spree: go with them, and make an occasion out of it: take them to lunch and then go on to get the the lens of their choice - you will both likely enjoy the experience far more and it will create a memory you will both cherish. That way, you can buy them the lens they need, rather than you think they want.
