Difference in wide angle or macro 35mm lens vs 24-105mm
Iluvphoto
Hello! I am interested in a 35mm either wide angle or macro. I have a Canon RF 24-105, Redline series, and was wanting to know if there is a huge difference between the lens I have, and either of the 35mm lenses. I would appreciate any guidance you can give me. Thank you!
2 REPLIES 2
rs-eos
Note that your zoom lens already has a 35mm focal length within its range.  So the only two reasons to go with a 35mm prime lens (assuming that's what you're looking at) would be the wider aperture (f/1.8) and that it is a macro lens.
Wider apertures allow you to work with lower light-levels and/or blur the background more.   Macro lenses allow you to get very close and small subjects can fill the entire frame.
Ricky
ebiggs1
Try this, set your current lens to 35mm and put a piece of gaffers tape on it so it won't move off 35mm. Live with it for a few shoots. Unless like Ricky opined, if the faster aperture is what you need I bet you find the current zoom is far better
EOS 1DX and many lenses.
