12-01-2024
10:21 PM
11:54 AM
I was taking photos today and usually i have clean not kinda out of focus photos but today was different. i was looking at my photos and realized one of my photos are kinda out of focus so i reaserch it and found out my lens af cpu could be damaged so i look at my lens and i find this big streak going through each one.and was wonder If this was normal.
12-02-2024 04:45 AM
Greetings ,
As you can see we both started asking the same questions. This condition is not a normal occurrence and this lens does appear to have seen some neglect or abuse.
If returning the lens is an option I would pursue that. If not, the lens can likely be repaired by Canon. Start by registering the lens in your My Canon account. From there, you can initiate a repair request.
12-02-2024 06:31 PM
No, not ANY camera shop. Some have repair facilities, others could recommend repair services or ship it out for you. Parts availability is a question. You ought to find out if Sigma has a repair service, like Canon does for their products. They could quote you on cost. The lens may or may not be worth repairing, versus buying another one from a good used equipment dealer, like KEH.com, MPB.com, or UsedPhotoPro.com. They give warranties.
12-02-2024 09:38 PM - edited 12-02-2024 09:42 PM
Well this is odd.No matter how close i look at those contacts,none seem to be bent.
Are you referring to the dark strips across the middle group of contacts?Because that's relatively normal.To be sure,clean them with a little alcohol
12-01-2024 10:59 PM - edited 12-01-2024 11:00 PM
What camera and what lens are you using?
None of my bodies or lenses I've ever owned had trough like indentions like the contacts in your photo. The next question I'll ask is are you using some type of adapter or TC on this lens currently or previously? If so, which? You'd have to put a lot of pressure on a lens contact to dent it like that
12-02-2024 12:42 AM
What lens is this, and what camera body? Is there any other device between lens and body?
12-02-2024 01:18 AM
Canon 4000d and sigma 150-500 ef no adapter and i dont put much pressure on the lens
12-02-2024 01:18 AM
Canon 4000d with sigma 150-500mm ef lens with no adapter
12-02-2024 01:19 AM
Although i did buy it used so the other may have
12-02-2024 01:27 AM
Well, the lens IS damaged, for sure. If this is the way you bought it, you got taken.
12-02-2024 02:24 AM
Dang 😞 thank you!
12-02-2024 02:36 AM
Also is the streak normal if it wasnt as bad??
12-02-2024 04:45 AM
Greetings ,
