EOS 80D studio photography lens recos and RF lens compatibility
KACPhotography7
I am completely new at photography still learning. I have a D 80 Canon camera. And I was wanting to get your advice for doing inside studio photography what is the best lens to use? And my other question is I’m completely new at R-F and E-F seems to me that the RF is better by what I am reading. But my other question is what R-F work on my camera Because by what I’m reading is for cameras that Do not have a mirror. If I’m not mistaken please get back in touch.
10 REPLIES 10
kvbarkley
VIP
VIP
RF lenses will not work on your camera. They only work on the mirrorless R series of bodies, not DSLR's like your D80.
For studio photography, *any* lens will work since you have total control of the lighting. It just comes down to focal length, macro capability and desired depth of field. The question is what you want to take pictures of:
food?
bugs?
jewelry?
artwork?
individual portraits?
group portraits?
deebatman316
RF lenses are INCOMPATIBLE with DSLR cameras stick with EF or EF-S lenses. There’s no adapter to make RF lenses work.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
Which one is better the EF or the EF-S What’s the difference between the two?
EF lenses are designed for Full Frame DSLRs and EOS 35mm Film SLRs. EF-S is an APS-C DSLR lens mount. EF-S lenses are NOT COMPATIBLE with Full Frame DSLRs. They physically won’t mount on them. This is intentionally designed this way. The mirror on a Full Frame DSLR or EOS 35mm Film SLRs would collide with it and cause serious damage. The lens is intentionally designed this way not the mount on the camera. But APS-C DSLRs are backwards compatible with Full Frame EF lenses. So any Full Frame EF lens will work on an APS-C DSLR. But the reverse isn’t true. All of the Rebel, XXXXD, XXXD series DSLRs, XXD ie 80D & 7D series. Are all APS-C cameras that accept EF-S. Canon’s early APS-C DSLR cameras the EOS D30, D60 & EOS 10D predate the EF-S Mount. These cameras can only use Full Frame EF lenses. You own an APS-C DSLR which can be used with any EF or EF-S lens.
-Demetrius
There are good and bad lenses in both mounts, neither is "better".
Ok, Let me ask you this I am Wanting to do is side studio photography of people. What Lens would you recommend??
kvbarkley
VIP
VIP
What lenses do you have?
mdphotography
Enthusiast
If you are "completely new", I'd start with tutorials: see if you can find any for D80 studio photography and see which lenses they're using.  Failing that, pay attention to aperture and focal length as that's what you'll be using as a comparison.   I feel like I get better/more responses when I say, "I'm comparing X, Y, and Z" so try to come up with 2-3 specific lenses and list the reason(s) you're considering each.
And don't forget used gear: a used high-end lens will probably be better than a new budget lens
March411
Whiz
Whiz
KACPhotography7, it is a difficult question to answer directly, some will say that for fixed focal length the 50mm, 85mm and 135mm when shooting close-ups. If you are shooting full length the 24mm and 35mm would be a decent choice.
Personally for fixed I like my 100mm or the 70-200mm zoom which I use frequently. Really a personal choice!
Regardless of which lenses you purchase purchasing the fastest lens the budget will allow will also be a benefit as you will be able to achieve some beautiful bokeh in your portraiture.
Marc
Windy City
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
