Close focus distance for RF100mm F2.8 L MACRO IS USM
wes1790
What is the distance between the subject and lens front [filter ring] at 1.4x maximum magnification for
RF100mm F2.8 L MACRO IS USM?
Does anyone have a chart showing subject size at various lens-to-subject distances?
3 REPLIES 3
rs-eos
Note that focusing distances are not typically computed from the front of the lens, but instead from the sensor.  Your camera should have a symbol of a circle with a line running through it (typically near the viewfinder).
Pages 13 and 14 of the User Manual should include all the information you're after (to include distances from the from the front of the lens).
Ricky
wes1790
I don't care how far it is from the sensor to the subject; what counts is the working distance from the front of the lens to the subject: 0.28' or 3.36" according to the user Manual. Thanks.  A chart of subject size and distance from the lens would still be helpful.
I found the information Ricky provided to be helpful.  MFD is an industry specification.  Since MFD is calculated from the subject to the sensor, this is the information provided by the manufacturer.
The lens is approx 5.8 in.  Add a filter its approx 5.825
Mag 1.4x is 10.32 in
Mag 1.0x is 11.04 in
Mag .5x is 15 in
Lens measurement is from the front of the lens to the flange.
Flange distance on an RF lens is 20mm or .787 in
So if you take the lens and filter (if applicable) 5.825 + the distance from the flange to the sensor .787 = 6.612 in
Mag 1.4x is 10.32 in - 6.612 in = 3.708 in
Mag 1.0x is 11.04 in - 6.612 in = 4.428 in
Mag .5x is 15 in - 6.612 in = 8.388 in
The MFD at 1.4x is 10.32.  The lens + filter is 5.825 in = 4.495 in. - (minus) the flange distance .787 in = 3.708 in
Someone should probably verify my calculations 🤣
