Circular Issues With Canon RF 15-35mm 2.8 taken on Canon R5
CK0
Hello!
I have had issues with this little circle appearing in my photos for my Canon 15-35 while taking long exposures. I can't seem to find the issue.
I am not sure if it is due to some correction if it is due to some ibis issue or maybe its the camera/lens itself. Anyway, I do have my high iso noise reduction mode on but also figured if I asked on here it would be best.
Here is the sample photos.
Thank you!
2V6A7376.jpeg2V6A7376.jpegIssues in the middle with circular patternIssues in the middle with circular pattern
rs-eos
That appears to be an interferance pattern.  Perhaps "Newton's rings".
Were these taken when on a tripod and lens IS and/or IBIS engaged? Though I don't know if that would lead to this.
Ricky
5 REPLIES 5
rs-eos
Ricky
It might be due to the lens filter I have on top. I do have ibis on one photo and have ibis off on another.
CK0
Ah, did not think to ask about an filters.  That could also perhaps lead to the issue.  What type of filter were you using? Variable-ND perhaps?
Ricky
CK0
justadude
Whiz
Whiz
I usually keep a UV filter on my lenses, but I always take them off for long exposure shots, especially at night.  Sometimes I get very faint reflections between the lens and the filter from any light source, including reflected moonlight... especially on the less expensive filters.
Gary
Lake Michigan Area MI
Digital Cameras: Canon EOS R6 Mk ll, EOS R8, EOS RP, ...and a few other brands
Film Cameras: Mostly Pentax, Kodak, and Zenit... and still heavily used
