03-21-2021 03:29 PM
I'm trying to determine if this lens only has one f stop-2.8, or a range of f stops? I know the new RF 600mm onky has one f stop (11), how abnout this lens?
03-21-2021 04:22 PM - edited 03-21-2021 04:22 PM
Unless the lens is specifically marked as having a single (and constant) aperture, the aperature can be understood as follows:
For a prime lens, only a single value will ever be displayed and it will denote the widest aperature available. The narrowest will depend upon the lens (e.g. f/16, f/22, f/32).
For a zoom lens, a single value denotes the widest aperature available across the entire zoom range. The narrowest aperture will depend upon the lens.
For a zoom lens with two values, they will denote the widest aperature at the widest focal length and most telephoto focal length respectively.
For your specific lens, you can use f/2.8 throughout the entire zoom range. The minimum aperature available is f/22
03-22-2021 10:52 AM
"I'm trying to determine if this lens only has one f stop-2.8, or a range of f stops?"
It is mostly common for most lenses I know of to not list all their available F-stops in its name.
"I know the new RF 600mm onky has one f stop (11)"
This lens was made with a single aperture, not a common practice BTW, but the fact it is named the Canon RF 600mm F11 IS STM Lens really isn't because it has only one aperture setting.
