09-07-2013 11:32 AM
I currently have a 29-90mm lens and need to buy a lens for outdoor weddings, indoor band photos and general picture taking.
I also need to purchase and external flash for the indoor band photos.
Please help!
I have done many hours of research and I can't figure out which lens to go with that's under $1,000.00.
Thank You!
09-07-2013 01:00 PM
Based on what you describe I'd look at the EF-S 17-55 f/2.8 IS USM lens. The relatively fast f/2.8 maximum aperture will help with indoor concerts and it covers the field of view of a 27-88mm lens on a full frame body.
As for a flash, the 430EXII is a nice compromise of size and features and refurbished copies can usually be found on Canon's USA online store.
09-07-2013 02:02 PM
If you don't mind, what is there difference between :
EF-S 15-85mm f/3.5-5.6 IS USM
EF-S 17-55mm f/2.8 IS USM
EF-S 17-85mm f/4-5.6 IS USM
I am trying to learn this on my own, my father was a photographer but has no interest in helping me.
I need to take a class, I can't keep all the research straight!
09-07-2013 02:52 PM - edited 09-07-2013 02:57 PM
09-07-2013 03:36 PM
Wow, thank you so much! I greatly appreciate your help! Seems I've finally found someone who knows their stuff 🙂
09-08-2013 09:40 AM - edited 09-08-2013 09:40 AM
In addition to the spot on info that Scott gave you, I will recommend you get and learn to use post processing software.
Some times it comes with the camera free but most times you need to purchase one. Probably the two best are Photoshop Elements 11 and/or Lightroom 5.
Some guys don't like to admit it but nearly 100% of the best photos taken in the world of photography are post processed.
Certainly you will want one for a wedding shoot.
BTW, my take on the EF-S 17-55mm f2.8 is, it is very fragile and you must use caution wiht it. Take care of it and it will be fine but it's construction is not the best it could be.
