12-19-2012 12:26 PM
I bought a refurb copy from Canon store - focus ring is loose, rattles when u touch it, but still works great. I called canon, got it RMA'd. By the way, awesome service from Canon, thank you.Well, I just now received a replacement lens, also a refurbished lens and it has the same identical issue... The focus ring is rattling/clicking when you pull on it back and forth, it is loose in the front to back direction. It also has a little play in the directions you would use when you're focusing... It is very frustrating!!! The zoom ring is nice and tight on both lenses, only the focus ring is loose, as if it's a little bit bigger than it should be - anybody else has this problem?
Thank you.
12-20-2012 12:56 PM
My son has this lens on his T2i. But I am probably not the person to ask about it because I never saw it as a very good lens. Just one of the many so-so lens' on the market. But I never noticed it having a unusually loose focus ring. But I suspect that is a subjective area and depends the individual.
12-20-2012 08:40 PM
If it's the 70-300 L IS it's a very good lens according to everything I've read. Is it a white lens or black one?
12-21-2012 07:04 AM
It is the L lens, white one. It is a very good lens, the only thing that bothers me is that loose focus ring. No other lens I own or have handled has this issue.
12-21-2012 02:29 PM
I was refering to the black version. I have no experience with the white one but I didi see this in a review of the white lens:
"The zoom and focus rings are very smooth with no play - and the zoom ring remains very smooth even while the lens is pointed up or down. Both rings are nicely sized and very well integrated into the lens barrel design."
12-21-2012 08:28 PM
12-26-2012 01:25 PM
Well, on Friday I received a 3rd copy of the lens and it also has the same issue - the focus ring is so loose it's rattling, clicking as well. I'm giving up on the refurb lenses from canon. I'm going to return this one as well. i'll try to order a brand new one from a store, see if it has this issue. I don't know if it happens during a refurbishing process or if they had a bad batch of them.
11-30-2014 02:47 PM
12-01-2014 09:38 AM
One question? You bought the "white" one from Best Buy? At any rate either will be out of warranty now.
