06-28-2024 07:04 AM
My camera is canon 6d use 50mm f1.8 stm sometime show error 01 something can use what Promblem
Lens is new
06-28-2024 08:11 AM - edited 06-28-2024 08:14 AM
Greetings ,
Error 01 is a lens communication failure. If this only happens with one lens, I would return it. If this is happening with more than one lens, I would inspect the gold contacts in the camera and make sure they are free of debris or dirt.
Ensure you are using OEM Canon batteries and memory cards of known good quality purchased from a reputable source. It might also be wise to reset the camera's main and custom settings to defaults for further testing. If the behavior continues with multiple lenses, I would consider sending the camera to Canon for inspection.
~CarePaks Are Worth It
06-28-2024 08:53 AM
I want to ask you something🙏 Now i try recond video can photo cannot what Promblem
06-28-2024 08:54 AM
Sometime can sometime anything no work
06-28-2024 11:27 AM
" I would inspect the gold contacts in the camera and make sure they are free of debris or dirt."
This rarely to never works or even helps but it is the only thing you can do yourself. Get a q-tip and some alcohol and rub gently both the lens and the camera contacts. If this doesn't help and I suspect it won't you need to send both lens and camera in for service.
06-28-2024 12:36 PM
Hi Ernie,
I didn't say wipe. Just visually inspect. 😎
06-29-2024 11:21 AM
"I didn't say wipe. Just visually inspect."
OK? 🤔
Repeated your advice and extended it. At this point to further extend the visual inspect, an almost useless q-tip cleaning is about the only step a novice can take. The OP may be one of the lucky ones where it did the trick. The battery and/or SD are very much not likely the problem either. Cameras or lenses or anything made by the hand of man will eventually fail and this may simply be the case here. Its broken.
Resetting the camera to factory is always step one.
