04-03-2021 06:43 AM
My 50mm f/1.4 worked Greta in the past but on my latest outing it would only go to f/2.0 on my EOS R. Doesn't matter of I'm in manual or any of the priority settings.
I've searched to see if there was a limitation setting similar to the auto iso but I can't find anything like that. The on screen setting adjustment also only shows f/2.0 as the lowest option.
Has anyone else experienced something like this? Amy suggestions?
04-03-2021 09:45 AM
Which adapter are you using to connect the EF 50mm lens to your EOS R?
04-03-2021 10:28 AM
First off reset you camera. Then try it again.
04-03-2021 12:29 PM
@BairStrokes wrote:My 50mm f/1.4 worked Greta in the past but on my latest outing it would only go to f/2.0 on my EOS R. Doesn't matter of I'm in manual or any of the priority settings.
Do you turn the camera off to mount or unmounting a lens? I think doing so is the recommended best practice for just about any Canon mirrorless camera.
Try resetting the camera, as previously suggested. Do not bother with tryin to clean lens contacts. As noted, if you are not using a Canon mount adapter and a Canon lens, then that could be a cause.
04-04-2021 09:48 AM
" Do not bother with tryin to clean lens contacts."
I second this. Don't do it.
04-04-2021 12:39 PM - edited 04-04-2021 12:40 PM
Its likely a Sigma Art:
Firmware download | Support | 50mm F1.4 DG HSM | Art | Lenses | SIGMA Corporation (sigma-global.com)
But the latest FW doesn't state anything about mirrorless, so I suspect as others have mentioned it has to do with settings or the adapter being used if not Canon.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
