02-03-2023 09:40 AM
I just purchased a "like new" R5 body and A "like new" Canon 17 mm Tilt shift lens. (this is my only body and my only lens so far)
The control ring on the camera will not operate the aperture on the lens. The setting on the camera reads f00 in manual mode.
Setting had been made to allow shutter to operate without lens attached (needed for a manual lens)
The adaptor is made by JJC (not Canon).
This combination (except for the adaptor) is used by many architectural photographers so I believe the cameral and lens should communicate.
Though the equipment was purchased used on ebay, I believe both sellers were original owners.
Can anyone direct me on this?
02-03-2023 05:27 PM
Are you by chance using the Canon EF 50mm F/1.8 STM if so that lens uses an Electronic Focus Ring. Make sure Manual Focus After One Shot/ Lens Electronic Manual Focus is Enabled. IF NOT the electronic focus ring WILL NOT WORK.
-Demetrius
Current Gear: EOS 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
02-03-2023 09:16 PM
Control Ring - Best price I've seen and free shipping.
Search Results | Canon U.S.A., Inc.
Hoping its your adapter
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
02-06-2023 01:57 PM
I appreciate your response to my predicament.
As it turned out, the problem was with the JJC adaptor. I received a canon adaptor today and everything works perfectly. There are several non-branded adaptor being sold and some have positive reviews (as did the one I bought) I am certainly going to exercise caution for future purchases.
02-06-2023 02:01 PM
Since you have had the same problem with two different EF lenses adapted for use on the RF mount camera, I would suspect the adapter itself is at fault. It's possible it has a short in the electronic connections, for example. Try a different adapter.
If I were working with a 17mm TS-E lens, I'd want one of the adapters that can accommodate drop in filters, because that lens cannot be fitted with standard filters.
Canon offers a drop-in adapter with choice of C-Pol or Variable ND filter. A clear filter for it is sold separately and is necessary in order to use the adapter without any filtration. You also can buy the C-Pol filter alone, if you got the adapter with the Vari ND... or vice versa.
There are 3rd party alternatives too. Kolari, Meike and Breakthrough are three brands that come to mind.
Meike's adapter is offered with a Vari ND and includes a clear filter as well. C-Pol and a dozen other types of special effects filters are available for it. Reviews are quite favorable.
Kolari offers more combinations and an even wider array of special effects filters.
Breakthrough Photography claims to have the widest selection of all. They have fewer special effects and more fixed strength ND filters, as well as some specialized for black & white, etc. Breakthrough also offers two different price/quality levels: more affordable "2X" and more premium "4X". There are differences in the glass and in the multi-coatings on the two different grades of filters.
AFAIK none of these drop-in filter systems are interchangeable.
There are other lenses where a drop-in adapter would be very helpful, such as Canon and other 14mm lenses, Canon EF 11-24mm, Sigma's 12-24mm in EF mount, etc.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
02-06-2023 02:28 PM
Thanks for the references. I was thinking I would buy the Canon adaptor with the drop ins. But given I had 3 new pieces of equipment that were not communicating, I opted to buy the less expensive adaptor during the trouble shooting phase. Now that it was determined that the JJC adaptor was the culprit and that the R5 and the lens do in fact communicate, I still need a way to install filters on the TS lens.
I may just return the basic Canon adaptor for the filter adaptor.
Many Thanks!
02-18-2023 01:03 PM
I managed to purchase the EF/Rf adaptor with the CP filter. I ended up keeping both the filter adaptor and the basic adaptor.
