which ink jet printer loads from the top
Mildred
1 REPLY 1
Ramona
Hello Mildred,
We have several inkjet printers that feed from the top (either via ADF or rear tray); so we can recommend the best printer for you, please provide us with the following information:
  1.  Will you need to have faxing ability on your new unit?
  2.  What operating system do you have on your computer (Windows XP, Vista, 7, 8 or Mac OS version)?
  3.  What is the largest size paper you will need to print from the unit?
  4.  Will you need the ability to scan 35 mm slides or film with the printer?
  5.  Will you need the ability to scan from the unit?
  6.  Is there a specific price range you are looking to stay within?
  7.  Will you need the option of using the printer wirelessly?
  8.  Will you need the ability to print photos and images directly from a memory card?
  9.  How many pages a month do you estimate you will be printing?
10.  What is the heaviest weight (in lbs) of paper that you plan on using in the printer?
11.  Will you need the ability to have the printer interface with an iPad, iPhone or Android device?
If this is a time-sensitive matter, additional support options are available at Contact Us.
